- Sep 10, 2024
I've never seen glue react to MDF like that, I'm surprised.
Hi Steve,
The MDF isn't a factor, polyurethane glue will do that on anything.
Go get yourself some Titebond II or similar, but make sure it actually says PVA.
Titebond 2 is Available
Portugal is a great country in many ways with some really crazy prices. Also, here we have big problems in finding what we need.
I originated in the UK and before Brexit, I would buy much through Amazon UK. That all changed since Brexit. Now I buy a lot from France, Germany and Spain through Amazon. Unfortunately, often, liquids will not be sent. The Titebond available here in Portugal from a big supplier as you see in the image, is only avalable online. 473 ml is about 16oz. Cost in US Dollars is about $50 plus delivery. Walmart appears to charge $6. . Just an example for fun. Perhaps, I just get all the prices wrong or I'm going crazy..
Hi Russ. I understood that. Over the time I've been reading on the forums I have seen so often Titebond mentioned. I suspect for the model boat builder it's ideal in consistency, drying time and more. As it appears we'll thought of, I attempted to buy it here in Portugal and was amazed that Leroy Merlin, a huge home decorating store here could ask such an inflated price and especially so when compared with Wallmart. It just seams unbelievable.! I used Titebond as an example,
Yup, those books definitely have to move.I was also amused by the 60 or so books that now need moving. Hope your health has settled.
Hi Steve, yes I have the supports in place. I'm doing a build log because I feel it is more fair to contribute a bit if possible. I've found the work of others often brilliant in many fields. The information on Russ's build log I would say is very valuable and a must read to anyone considering the Oseberg., are you going to put the stem supports on?
Thank you.Looking foreward to seeing your progress.
Hi pugwash,Looking foreward to seeing your progress.
After a sudden rush of blood to the head I just ordered the book by Vibeke Bischoff; hope I'm not disappointed.
Hi Ashley,Deck Supports.
The deck of the Oseberg is created by planks set between the main beams of the ship, there are many of them.
Attaching the Supports
Attached to the main beams are small support strips glued to the beams themselves. At the same time, they rest upon the stringers. Each of the parts are numbered and require fitment into their respective positions. Fitting is straight forward apart from the central section. With the majority of the parts checked and sanded a tiny amount, they may be fitted and clamped into position. In my case, I could see slight variation in levelness if simply placed and clamped upon the stringers. This would have lead to uneven planking along the cross members. At this point, I also wished to maintain perhaps .5mm height difference between cross member and the slightly lower plank. I used dry fit some of the decking boards for alignment.
Showing the Level of the Decking being Catered For
It's True. You do Need Many Clamps
The More Complicated Part
The deck support sections either side of the mast I have not photographed and displayed as I undertake any Dremel shaping works in another area where I failed to take the camera and the forgot to take photos.. For those considering the building of this kit, I would say, don’t be deterred by the shaping of these parts. It is not difficult with a little common sense. That said, precision is required as I feel, in the case of the Oseberg, if a good result is hoped for, attention is required because as I am discovering, the is very little if no room for error.
Conclusion
I am making more progress than I thought I would. I'm getting close to doing the planking.Oh dear. How will I do there. I've seen a few problems with others. Me, we'll see. Baby steps perhaps.
