CAF 1:48 HMS Granado cross Section
Houston, Texas, Park City, Utah
NEW BUILD LOG OF CAF'S 1:48 CROSS SECTION OF HMS GRANADO
The Rosas Houston Shipyard is currently on the last stages of three ships: CAF1:48 HMS Enterprize, La Coureur, and Trident's 1:48 HMS Alert. The shipyard started operations in December 2019, and has been building intermittently (sometimes not all for months), ever since.
The three ships will be completed before this summer in order to make room for a huge project: Dockyards' 1:48 full frame HMS Enterprize. Materials have been ordered from Dockyards and will be coming from the forests of China, hopefully in the near future.
The shipyard workers move from Texas to Utah for several weeks during the winter (ski season) and from June to September ( to avoid Houston heat, bike and hike). In order to work on the backlog of ship contracts (lots of kits around), a smaller shipyard has been inaugurated in Park City, Utah. The shipyard will work in parallel with and also be an aircraft and automobile factory.
This is The Rosas' shipyard in Park City Utah.
Work has begun in mid February on CAF's 1:48 cross section of HMS Granado
The kit's wood is excellent, close-grained, sands easily. Frame futtocks are CNC, the spacers are either thin wood or 3-d printed plastic. Instructions are clear, with a couple of labeling mistakes that are easily identified. So far, the kit is a lot of fun, and superb. I picked it because it is not a huge project (could be done in the afternoons after a ski day) , and the construction of its intricate and complex frames will be a good training for the biggie 1:48 Dockyards' Enterprize to be built in Houston.
The cross section is made up of 9 frames (From frame # 6 to frame #14 of the full framed ship); each frame made up of two half-frames (actually futtocks and floor timbers) - for simplicity, I am calling them half frames, "A" and "B". The frames are complex.
The picture above is half-frame "A" of # 6 frame Shows the CNC-cut floor timbers, chocks and futtocks.
This is completed frame # 6, not sanded. To build each frame, I glued the trimmed and sanded futtocks of half-frame "B" to the frame plan on a poster board with tacky glue, then glued the futtocks to each other with wood glue; then glued half-frame "A" on top of "B" with wood glue. Plastic spacers (3-D printed plastic) are inserted between the half frames to space the top timbers and futtocks 3 and 4. Did I say the frames are complex !
The building jig is a real pleasure., It is made of engraved, high quality clear acrylic panels and was easy to build.
Picture above shows frame # 6 dry-fitted on top of the keel. Notice the spacing between the top timbers.
Later I plan to insert metal (.6mm wire) and wood treenails.
Another picture of frame # 6 dry-fitted on the keel, inside the building jig.
The shipyard (me) has completed (Feb 24th) frame 12, with frames # 13 and # 14 still to be built.
This will be documented in about 3-4 weeks since the Utah shipyard is on work stoppage until sometime in March (I'm back in Texas until then, working on my other projects.
Have fun.
Alex R
NEW BUILD LOG OF CAF'S 1:48 SECTION OF HMS GRANADO
This will be documented in about 3-4 weeks since the Utah shipyard is on work stoppage until sometime in March (I'm back in Texas until then, working on my other three projects.
This shows the Houston shipyard with progress on CAF's 1:48 HMS Enterprize....Further updates will be given on each ship's build logs. (other ships ships can be seen in the far background. .Whew....busy...
To be continued.
Have fun.
Alex R
Good afternoon Alex. Ahhh good to see the Enterprise and Lovely work on the frames for your HMS Granado. I wonder why Tom did not make the Enterprise frames as accurately as the Granado?? In fact I’m a little disappointed in the Enterprise frames for lack of detail etc. Anyway I have pulled up a chair to check this out. Have fun. Cheers Grant
Over the last couple of weeks frames #6 to # 14 were assembled, and glued onto the keel. They fit tightly into all the slots of the build jig.
Next phase (to be started in early June) will be to finish the upper bulwarks details, treenail the frames' futtocks and finish sanding. A lot of fun so far.
Alex R
View attachment 511139View attachment 511140
Alex R
Hi Alex. Congrats for this astonishing kick off on one of my favourite kits ever. I see you have got a plenty of meat ready for the BBQ as well. Your shelf would be surviving me at my age (56) for sure. Cheers!
Progress on CAF's 1:48 c ross section:
First pic shows the assembled frames with keelson and the all-important deck clamps. It took some ingenuity to get them positioned perfectly, but it is the most important step in this model. Screw the position and symmetry of the deck clamps and everything else will be ruined!
Second pic shows the inner planking with thick stuff.
The third pic shows the futtock riders placed over the frames, before the inner planking.
The fifth and sixth pictures show the riders and the beams placed in their positions-unglued of course.
Seventh pic shows a beam dry fit on the clamp.
Next: finish sand the inner planking and then sand bevels and slots for the thick stuff on each of the five futtock riders. It will take a while. The starboard side is left mostly unplanked, the port side is fully planked.
Really fun so far. Im kinda happy with it.
Wouldn't it be nice if one could just sand away one's mistakes in life, as we can do with wood ?
I'll update soon.
Thanks
Alex R
Progress on CAF's 1:48 HMS Granado cross section.
The acrylic build jig has worked very well. The lower decks, shell room and structure is essentially finished. Half of the ship will be planked, the other half left un -planked to show the structural timbers.
Next, build the mortar box and plank the upper deck and bulwarks. After that, the cross section will be removed from the jig to sand and then plank the ouitside.
Alex R
Alex R
View attachment 532281View attachment 532282View attachment 532284View attachment 532288
Very very cool Alex. Very comprehensive in the details. Cheers Grant
Thanks Grant.
It has been a lot of fun, intricate, but small in scope. I'll post more progress in a few days. Hopefully I will finish it ( a rare occurrence for me) before the summer is out. I'll get back to Houston and continue with Enterprise in the fall. I really like cross sections. Next summer ( in Utah ) will start the Bon Homme Richard cross section.
Thanks Again.
AR
