Good afternoon Vic. This drives me nuts and I still do it…. Never learnOops! The clamps made dents in the balsa. Time to buy some wood putty. I tried using pins, but they didn’t hold. Next time I’ll use plywood sheets to even out the pressure. View attachment 533264
. Cheers GrantI’m just glad it will all be covered, Grant!Good afternoon Vic. This drives me nuts and I still do it…. Never learn. Cheers Grant
Like I said... BALSA!Good afternoon Vic. This drives me nuts and I still do it…. Never learn. Cheers Grant
Yep. I just tried masking tape and that seemed to work okay. I just bought some epoxy and fiberglass. I'll test it out on some soft wood to see how it works. Never used it before. Supposedly it will make it stronger.Like I said... BALSA!
i presume there was no frame under that section of the hull skin were the clamp was? why not use masking tape to hold the balsa skin in place till the glue dries instead of the clamps?
Epoxy and fiberglas will make a hard skin on the wood, but it's STILL balsa.Yep. I just tried masking tape and that seemed to work okay. I just bought some epoxy and fiberglass. I'll test it out on some soft wood to see how it works. Never used it before. Supposedly it will make it stronger.
A just saw a video on that. I’ll watch it again a couple of times and then practice on a piece of plywood.A tip. I learned this the hard way! Don’t try to glue the fiberglass cloth on to the model with the epoxy. If you do you will wind up with a wrinkled mess. The correct way is to first drape the cloth over the model and then apply the epoxy, working it into the weave of the cloth with a squeegee.
Roger
Try wetting area and heating with plank bender or similar tool to heat wood, often the fibers relax and dent comes mostly out.Oops! The clamps made dents in the balsa. Time to buy some wood putty. I tried using pins, but they didn’t hold. Next time I’ll use plywood sheets to even out the pressure. View attachment 533264
I have a feeling that might be especially true with balsa.Try wetting area and heating with plank bender or similar tool to heat wood, often the fibers relax and dent comes mostly out.
This would pretty much be a scratch build if it weren’t for the balsa. Because of the size, it would also be cost prohibitive to replace the balsa. This is what the owner wants. The kit was a Christmas gift to him. I will do the best I can and try to make it as strong as I can in the process.I will also say thanks to Kurt Konrath. I did not know about wetting and heating the area of dented balsa. In my ship yard the only place for balsa is in filling bow and stern blocks to get an exact shape before fibreglassing. Weight is never a problem with my ship models, but strength and durability is, therefore balsa sheeting is only used in building my aircraft where weight is always a consideration.
