**VIEW THREAD HERE** |
Look for the right one you needed, Mike. There are 2 sets.Thank you @dockattner , @Jack Sparrow and @Kurt Konrath for your replies.
I will just order a set and give it a try. Elsewhere on the web I have read that it works better with the harder types of wood, contrary to what I assumed, also depending on the grain.
I have the set, and you have to hold low to bottom edge being used, or mount in vise with top side for use and hold strip with top board to apply pressure to help mold the strip.
1. Make your own scrapers out of single edge razor blades. Much cheaper. These scrapers dull easily, but are easy to "tune -up". A Dremel tool and the abrasive cutting disks work fine to shape the cutters.Does anyone have experience with the Artesania Latina scraper tool, or so called 'micro shaper'?
Does it work at all, or just with the softer varieties of wood?
Son geniales¿Alguien tiene experiencia con la herramienta raspadora de Artesanía Latina, o también llamada 'micro moldeadora'?
¿Funciona o sólo con las variedades de madera más blandas?
I am with Paul on this. They hold the sharp edge better and cost about $0.10 each cents at any local hardware store. Pieces of an old hacksaw blade is even cheaper. You can grind whatever shape you want with a thin grinding wheel in a Dremel, or other hand held drill. The disks are about $0.12 each but last a good while.But I've also just made my own with single edge razor blades and box cutter blades.
Yes, they do their job very well.Does anyone have experience with the Artesania Latina scraper tool, or so called 'micro shaper'?
They work very well.Does anyone have experience with the Artesania Latina scraper tool, or so called 'micro shaper'?
Ater using these for a while, it appears to me that it is not the hardness of the wood which is the major factor, but how fine the grain is. Walnut, notoriously coarse grained and hard, wants to be torn and not cut using these forms, but if you make many light cuts, you can carve the walnut into the desired, molded shape. Clamping the scraper close to the cutting edge supports the scraper well, and aid in reducing chatter when drawing a wood strip across the scraper's shaping edge.Thank you @dockattner , @Jack Sparrow and @Kurt Konrath for your replies.
Hi Mike. I use the scraper a different way. I place the strip of wood on a flat surface and then slide the scraper along the wood strip (rather than mounting the scraper in a vice). Not sure my way is better - just sharing my experience so you can try to see which works best for you.The two sets of AL micro shapers I ordered (set A and B) arrived today. I immediatly put them to the test. With the softer basswood it did not work out so well, but with a 2x4 strip of walnut I got reasonable results for a first attempt. It is time consuming though, and time will tell how long they will retain their sharpness. I do not see myself dremeling razor blades however.
Thank you all for your input.
