Ok, after all my ranting, everything turned out well. The rear stern sheet sits on the ledge between the two transom parts and the stern transom knee. The other part of the stern sheet is sanded and fits snug between the sheer strakes. I removed the two stern thwart knees and will replace them so they reach higher and add support to that sheet. The thwart that partially surrounds the daggerboard case needed the most sanding to fit. I had done this earlier before I relocated the daggerboard case and ended up cutting too much off. I added a piece of scrap to the end of it and now have it sanded to fit correctly. The forward thwart needed the least sanding but needed the two notches deepened. I used my dremel scroll saw to make a series of cuts into each notch and then my #11 blade to clean up the notch. I am now happy with the results.
Now to move on to the floor boards.
