Thanks Brian, even at 5 mm they're stick out well past the frames. Oh and I meant mm not cm.I would suggest the gunports should be protruding no further than the frames.
This is true on British ships as well. I have not seen any formulas though with relative sizes of gun ports for various calibers, which would be interesting to see. Contemporary drawings are a good source for sizing the port opening sizes for various calibers. Measuring several ships they seem to be pretty consistent. The sizes I measured are about:In my research on the Swedish ship VASA, I learned that the dimensions of its gun ports decreased in size as the size of the cannons decreased.
From looking a pictures in the booklet it comes with they do not protrude either side.I was looking at some photos of your build log to get some better context of your build. I'm not that familiar with the HMS Onterio, but, if the gunports are meant to be perfectly flush with the hull, I agree with Bryian. If they are meant to portrude from the hull a bit, I'd take one of the planks that you'll use for the outer hull, place it next to the gunport on top of the rib/frame, and then mark that thickness on the gun ports. That way you'll have a better idea of how much the gunports will protude on the finished product.
On further reading the instructions that say to use the two 50cm long 3x10 mm strips, the gun ports are attached in between the internal and external planking. So the ports are glued to the outside of the internal planking, then the ports are cut from the outside in.If I understand your question correctly, you’re asking about the length of the gunport framing through the side of the ship, rather than height and width. While Allan’s description is historically accurate for actual ship construction, what I have observed on a number of kits and builds (as per the instructions) is that the gun port is cut out of the planking with the lining going all the way through and sanded flush. Probably not historically accurate, but I think it explains what you see in the instructions.
The reason yours seems to be standing so proud is, I think, because it is butted against one layer of planking (vice going through) and the other (outer) layer of planking is not yet installed.
The alternative, and possibly easier/more accurate, method would be to sand your gunport frame down flush with the frame, open the gunport on the interior planking, add the exterior planking, then open the port on the exterior planking.
All of that is assuming I understood your question correctly.
Thanks Alan, there are 5 sweep ports on each side, also two sheave ports each side.On ships built by the British the ports are formed by the frames on each side and sills/lintels on top and bottom. They then get linings on the sides and bottom, but not the top of the port. This is all well and good, but for a plank on bulkhead it requires some jury rigging as in the first sketch below. In any case the planking covers the frames and sills. The edges of the linings are not covered as they are the stops for the ports which are flush with the planking when closed. Is this model the HMS Ontario 1780? Looking at the contemporary drawing of Ontario (22) 1780 at RMG, there are no sweep ports shown. Whether they were just left off the drawing for some reason but actually on the ship, maybe some member here will have better contemporary based information.
Gun port construction on plank on bulkhead
Gunport construction on plank on frame
Sweep port sketch below is based on drawing from Peter Goodwin on page 191 if The Construction and Fitting of the English Man of War.
Drawing of Ontario 1780 from the RMG Collections website.
As I mentioned previously, at the scale we generally build in, these small increments will not be noticeable.
the ports on the lower deck and the square ports in the transom are about 72-75 cm wide and 74-77 cm tall (interior of the opening; the port lid would be about 10 cm/4 inches larger in both dimensions) and the ports of the middle deck are about 67 cm wide and 62-65 cm tall
Thank you very much Neil for your response. Did you get this from the Arthur Britton Smith book Legend of the Lake? I would have loved to meet him. He was a veteran of the Normandy invasion and lived to be 103 years old. For a heart rending few moments, the following interview is worth watching. Sorry to go off track, but sometimes research yields wonderful side information and this find made my entire week!Thanks Alan, there are 5 sweep ports on each side, also two sheave ports each side.
No it's actually in the plans for this ship.Thank you very much Neil for your response. Did you get this from the Arthur Britton Smith book Legend of the Lake? I would have loved to meet him. He was a veteran of the Normandy invasion and lived to be 103 years old. For a heart rending few moments, the following interview is worth watching. Sorry to go off track, but sometimes research yields wonderful side information and this find made my entire week!
Just forget the Rmg plans lolHi Neil,
Which plans? The RMG contemporary plans omitted them, thus my confusion and reference to the A. B. Smith drawings. How would these be installed on a POB? For a fully framed model it is straight forward, but not so much for POB. As they are so small I am guessing it is best to just cut holes in the planking and glue in the 12X10 lids and hinges.
