ModelShipways Norwegian Sailing Pram In Progress
Ok, after all my ranting, everything turned out well. The rear stern sheet sits on the ledge between the two transom parts and the stern transom knee. The other part of the stern sheet is sanded and fits snug between the sheer strakes. I removed the two stern thwart knees and will replace them so they reach higher and add support to that sheet. The thwart that partially surrounds the daggerboard case needed the most sanding to fit. I had done this earlier before I relocated the daggerboard case and ended up cutting too much off. I added a piece of scrap to the end of it and now have it sanded to fit correctly. The forward thwart needed the least sanding but needed the two notches deepened. I used my dremel scroll saw to make a series of cuts into each notch and then my #11 blade to clean up the notch. I am now happy with the results.
Now to move on to the floor boards.
The hull has been primed and is now drying. I will next sand it and paint it. While I am waiting to paint, I have been working on the tiller and re-reading the next steps. This is where I feel the instructions are very confusing.
I have joined the three tiller parts and installed the pin in them. I don't have small hammer so I grasped the pin in the jaws of needle nose pliers and hit it with hammer. I think that served the same purpose. Question is, am I supposed to use same 1/16 wire for the tiller extension? Seems extension is too narrow and will split.
Next I started looking at installing the various hardware pieces. I found it confusing as to which photo etched brass pieces were what. So I took a picture and then went through directions and labeled them as I see them. Here is the picture. Do I have these correct?
20250325_152100.jpg.
Thanks for looking.
I believe you have those correct. I found that most of the holes were too small for the parts and nails and had to be enlarged. A few of the items like the oar locks I just glued into place using CA.
Rob
The Pram has been painted and I have started installing hardware. I installed the stay plate on the bow transom. I used a Dremel cutoff wheel to cut the brass tube to simulate the hex nut. Much easier using Dremel for this. For the two stay plates on the side, I merely glued them in the slots using CA. What is the best way to open up the holes in the photo etched parts to accept the brass nails? I got tired of messing with those little pieces that I would switch to working on the mast. I glued the two halves of the square mast and started assembling the spar shaping jig. Of course like everyone else there is a fifth notched piece that is missing. I will try to make one from the scrap wood. Did others do this or just omit one and if so which hole did you leave empty?
Here are pictures of the painted hull.
When the directions said to check measurement at the widest point I measured exactly 3 3/4" from the outside edges of the sheer strake. Usually you would expect to do some minor sanding to fit. I have a Drexel scroll saw that I can use to cut them quickly but afraid of cutting them too short. I'll try to file them. For the stern sheets, I'll probably have to build up the knees to keep everything level.
I had to shim to get the stern sheets level. Wasn't a big thing and it looks good now.
Reading the instructions, they say it can be done with or without the bent bottom... thus there will HAVE to be a bit of extra wood somewhere to allow the kit pieces to work with either option.
Also the thing to wonder, is it better to thin the frames to 1/16" BEFORE any assembly starts?
Ok, more frustrations. It's been several days since last post. I have completed gluing the flooring and the thwarts in place and proceeded working on the rudder. Used the dremel cutoff wheel to cut the tiny brass tubing pieces, and left many of them hiding somewhere on my basement floor. Tried using tweezers to sand those little devils and lost several more that took off flying to who knows where. Used CA glue to attach them to the gudgeons and attached those to the stern transom. Proceeded to work on the pintles. Why oh why did they make the brass pintle pieces so short? I saw on an older build log, don't know if it was on this site or Model Ship World, where the pintles were much longer. Also, our directions show them longer. Anyway, got those attached to the rudder also using CA. Installed the rudder on the ship and was getting ready to take pictures but realized I didn't have the tiller attached. Went to do that and the little tubing pieces fell off the gudgeons and went off to join their fellow friends. Off to the store to buy epoxy. Cut new brass tubing pieces and epoxied them to the gudgeons and now have it all together ready to take pictures.20250404_145435.jpg20250404_145512.jpg
Way too much fun.
Ok, now let's move onto the mast. I glued the two mast halves together and proceeded to drill the required holes. Directions specify a hole 3/8" and one 5/16" from the top. Wow, this puts the holes nearly on top of the predrilled hole. Can this be right? Looked at the diagram of the mast on page 5 and this didn't look correct. Ok, maybe they meant from the top hole. Is this correct?
Ok, more frustrations. It's been several days since last post. I have completed gluing the flooring and the thwarts in place and proceeded working on the rudder. Used the dremel cutoff wheel to cut the tiny brass tubing pieces, and left many of them hiding somewhere on my basement floor. Tried using tweezers to sand those little devils and lost several more that took off flying to who knows where. Used CA glue to attach them to the gudgeons and attached those to the stern transom. Proceeded to work on the pintles. Why oh why did they make the brass pintle pieces so short? I saw on an older build log, don't know if it was on this site or Model Ship World, where the pintles were much longer. Also, our directions show them longer. Anyway, got those attached to the rudder also using CA. Installed the rudder on the ship and was getting ready to take pictures but realized I didn't have the tiller attached. Went to do that and the little tubing pieces fell off the gudgeons and went off to join their fellow friends. Off to the store to buy epoxy. Cut new brass tubing pieces and epoxied them to the gudgeons and now have it all together ready to take pictures.View attachment 511746View attachment 511747
Way too much fun.
Lovely progress
Way too much fun.
I believe I cut the brass tubing using a small razor saw. It is actually quite soft. I agree with you 100% that the gudgeons and pintles are really difficult to work with and too short. I had the rudder fall off countless times. Instead of CA glue I used silver solder to solder the pieces together. It is actually quite easy to do and makes for a really solid join. I have to say your boat is really looking great!
I think I'm on the home stretch. I completed making the sail and I'm now working on the three stays to hold up the mast. Here is a list of my latest gripes with this kit. The pattern for the sail is too small. When lashing it to the gaff and to the boom, it does not reach the outer holes on both the gaff and boom.
When wiring the block on the traveler, I did not have enough of the thin wire left to make the twist. I stripped some 22 gauge hookup wire and tried to use it but it was too thick, plus it wasn't copper. I ended up using the copper wire provided without the twist by just wrapping it around the back of the block and gluing it. I don't believe I wasted any of the wire making the eyes on the gaff and boom. Just a 1/2 inch more would have been great. Same thing with the .3mm line for the lashings. I had enough for those but when I went to wrap the the loops on the stays I didn't have any to use. Will have to rob my wife's sewing basket for some thread. On the other hand I will probably have 5 feet of the .7mm line left over. Will post pictures shortly.
Here is a picture of my sail lashed to gaff and boom. I used a non-stick cookie sheet to make the sail. unfortunately the sheet had some small cuts in the coating which resulted in some small rust stains on the sail. Oh well, sails out in the weather will get marks on them. Notice the extra line needed to stretch to the holes in the gaff and boom.
Here I am in the process of rigging the stay lines. Once I get the loops in the lines glued and everything adjusted, I will go back lash some tan thread around them.
I'm getting close to the end. Hang the sail, touch up painting, and staining the stand. Oh, and did I forget the oars. I'll be up sh..t creek without a paddle.
I have completed the Sailing Pram. I am not completely satisfied with how it turned out. My initial rigging of the stays resulted in the boom just about resting on the tiller. I was able to redo the fore stay to lean the mast forward just a little. To lean it more would have required redoing the back stays but I didnt have enough of the 0.7 line to do these.
My next project will be the Lobster Smack from Midway kits which I accidentally ordered. Probably start that in June. In the meantime, I have some model railroad projects work on. After the Smack, I have my mind set on the Occre Albatros kit which they label as a kit for beginners. Doesn't look like that to me but I very much look forward to tackling it.
You did a great job in my opinion, including realizing and not being completely satisfied when something was amiss. Looks like you are ready for those bigger things :)
For your upcoming projects after the smack,,,,,,
Prioritize what's important to you, be it complexity, quality, accuracy, price, etc, A gift is having many build logs here that you can search to help you in your decision making not to mention a lot of experience from others if you ask for their input.
Thanks Allen. As for priority for the next project after the smack, I'm looking for a challenge, but something that's would make me proud to display. I have watched several build videos of the Albatros and feel it would accomplish that. Also the Occre kits seem to be well liked by others.
Hello from Denver! - I am currently building this same Pram. This is my second build, first being the Dory. I have enjoyed both - so far. I have most of the woodwork finished on the Pram and am just starting to undertake the etched metal components. After installing the "Stay Plates", "backstay straps" and front "Eyebolt" I am ready to move on to the "Oarlock plates" - This is where the project is no longer fun and may stall. So Im reaching out to this board for some opinion. The following photo illustrates my issue. The instruction says to fit the oarlock plates onto the "Rowlock pads" using CA. OK, fine, easy enough. Then, using a #71 drill bit drill through the plates to open up the holes for the "Bolt shafts" BOLT SHAFTS? - Are the talking about the 16 small brass nails that were included in the kit? I can find NO reference to these 16 nails in the instruction sheet. If they are, the appear to be way out of scale for this intended purpose. These nails are too big for the plates. I used one for the Backstay plates on the mast but took lots of finesse by drilling out the plates to fit that "bolt" - That was not fun, but I got it. - Still looks out of scale to me. I even tried cutting some of the smallest brass rod to fashion the bolts, but that did not work well for me when I was assembling the tiller - as I kept bending the brass attempting to mushroom the head. I finally got it after my third attempt. Frustrating got sure - this hobby is supposed to be fun - right?
Sorry for hijacking the thread, and kudos to the builder OldeManToad for completing the kit. Your work is beautiful and I hope mine turns out half as good as yours. I still have the metal work for the rudder gudgeons and pintles to deal with as well as the rigging to task. I, like others find the instructions at about 85% helpful - 15% confusing and unclear; maybe that is the idea to promote problem solving. Thank you for the others who have offered advise on other build logs on this forum. It is a great resource. I have enjoyed the wood portion of these builds and think I have a good handle of those basics. My 67 year old eyes and hands make it a bit of a challenge but I think I do OK.
Thank you for the compliment. You think the warlocks were no fun, wait till you work on the gudgeons and pintles. For the oarlocks I simply placed them on a piece of scrap wood and drilled the holes to make them bigger. Also be aware the sail pattern is too small. You might want to scan it and then increase the size until it looks right.
Your Pram looks great so far.
