Hi Brian,Hello friends,
I have glued up the segmented hull of the ship and filled the seam with Tamiya putty. In addition, I have cleaned the model with detergent and warm water to remove any contamination as per instructions. Next step was priming the hull with grey plastic primer and then a fine sand with 800 grit wet and dry sandpaper.
A few photos of the excellent fine detail of the 3D printing process.
View attachment 532956View attachment 532957View attachment 532958
Hi Steve,Hi Brian,
Were the anchors, chains and hawsepipes all part of the printed bow section, or did you add those in? If they are integral to the mould, that is some amazing detail.
Hello Jim,The amount of 3D print details is awesome! However, I see that there are still possible ways to improve using generic PE parts for this era. Some of them are the ladders and doors, IMHO.
Is the masking tape technique you mentioned for doing pixilized camo on the ship, which I have used for several armor builds, or some other effect. I’m very interested if the latter.Hello friends,
I have started painting the decks with my airbrush. Although the colour looks too bright, I’m planning on toning it down with some salt effects wash coat at a later stage when I weather the model.
In addition, thought I would try a masking tape technique I’ve seen several model builders utilise with hundreds of small squares of tape.
I will post the results soon. Thanks for your interest.View attachment 533414View attachment 533415View attachment 533416View attachment 533417View attachment 533418
Looking good Brian.Hi guys,
I have put in a considerable and enjoyable amount of time painting my model with an airbrush the last few weeks.
I would say I spent almost a week just masking up all the fittings with tape before painting. I carefully did the camouflage following photos of the real ship circa 1944~ 45 era.
It’s my interpretation of colours following the world of warships videos. I know it’s probably not 100 % accurate, but I’m pleased with the results so far.
I still have to apply the black “boot topping” along the waterline, and fit the secondary guns and multiple other deck fittings.
A few photos below of my progress.
View attachment 535456View attachment 535457View attachment 535458View attachment 535459
, thank you David.were the life rafts separate pieces or printed onto the turret sides?
