POB 1/48 Hayling - Modelship Dockyard
Your work is fantastic Jackie, but I'm just a bit confused. The first words you posted in the log were:
Yet ... it sure looks like POF. :confused: Could you explain why you say this is a POB build?
You are right, it will looks like a POF model eventually. I said that cuz the build still goes through a traditional POB process. Coffee
Great idea! That's much better! May I ask you how you removed char off the tiny lights frames?
Hi Albert, I used ammonia and hydrogen peroxide wood bleach to remove those char (laster marks). Pls wear gloves or use your tweezers. Always trial before use.
I purchased them from a local hobbyshop. If not, try local chemical shop, formula and method can be found on Google.
I was hesitated for quite a while over the deck plank width, but eventually followed the one provided in the kit, which is 4 mm.
This is becuz I would like to employ the original plank joggling in the kit.
Looks a bit stressful than the pattern of Antscherl's Hoy deck. And of course, more effort was spent to capping the deck.
Wow, I wouldn't have wanted to be standing watch on the quarterdeck during a stormy night in rough seas! One good wave breaking over the rail and you're shark fodder.
I was on stern watch( or MOB) at stormy 4AM on a barque AND that was my first sailing overnight at sea Ship-1
Here is the back door. not bad. The color of cherry wood is the only thing to complain about. Again, just personal preference, these cherry are far more better then the cherry I have in other kits before.
This 10 AUD Laser Level from Taobao/Aliexpress was very helpful for marking rib position. Masking taps made the whole thing tidy when I mark and drill for nails.
