Well done Nigel. Its a great project.
Well done Nigel. Its a great project.![]()
Nigel, it's a real beauty and I'm learning a lot. Enjoy your new project! Magic Mike
Hi ShotaDear Nigel
Its looks a unique project, I will keep following with great curiosity
Given the precision with which you are executing this, it must be an illusion caused by perspective, but it looks like the holes on the valve side and the opposite side are not perfectly aligned. Would that cause a problem later?Bolton part nine
Using the DRO I drilled the through holes that take the studs that clamp valve cover and chest to the cylinder block.
The casting was then clamped vertically in the vice. Again using an edge finder and centre function on the DRO I was able to accurately locate the hole for the valve rod and gland.
The hole for the rod was drilled undersize at 9/64" and then counterbored tapping size for a 5/32 x 32 TPI to a depth of 6mm measuring using the Quills digital depth gauge.
Finally the 9/64 hole was then finished using a 5/32" Reamer to obtain a smooth bearing finish.
The counterbored hole will be tapped after the piece goes into the lathe to turn and finish the outer diameter of the boss.
Funny what the camera does. I looked at the part again after posting these pics as things do look off in certain aspects, mainly the valve rod hole does not look in the middle but when you eyeball everything square on, there are no visible discrepancies to the naked eye.Given the precision with which you are executing this, it must be an illusion caused by perspective, but it looks like the holes on the valve side and the opposite side are not perfectly aligned. Would that cause a problem later?
