Norwegian Sailing Pram Build
Staten Island, NY
I am now working on my second ever wooden ship (boat) build. My first build was the Grand Banks Dory, part of the Shipwright of Old trio.
I started about 4 weeks ago. Three weeks ago I had a hip transplant, which delayed further progress. I can finally sit for more than 10 minutes at my work table.
I am trying to apply what I learned during the Dory build, and from reading other Pram build logs.
Lesson One: Sand, seal, sand, seal,... We will see how well I did with sanding and sealing when I finally apply paint.
I added the bow and transom knees, and aligned and attached the upper transom. Pretty confident I was able square them up well.
Next up was beveling the edges. I made the cuts around the center tab at the bottom of the transom, per instructions. Further comment on that later.
I eased the edges of the knees, and drilled through the hole in the bow through the bow knee.
It took three tries to finish drilling out the hole through the bow knee. As gently as I went I split the knee twice. Each time repaired with CA. Will probably need to consider some sort of backing or jig for any future such efforts.
I set up the Building Board, per instructions, and placed the bow and transom.
Since the transom brace is NOT glued in place the transom wobbled, making planking alignment an issue.
UPDATE: An issue I had with the building board was the misalignment of the two forms. First, the tabs of the forms were longer than the slots in the board. I had to judiciously sand down the ends, slowly and evenly, to make the boards fit. Snugly. Second, the boards did not stand square. To remedy this I sued a file to sand one top edge and the opposite lower edge of the slot. Using the above image, form 25 is leaning aft. To help it align vertical I sanded down the top long edge on the bow side, and the bottom edge on the stern side. That allowed me to align the forms vertically without opening the slot too much. The snug fit from right to left helps keep the form in place.
I glued two spacers (left over from the Dory build) to the building board to fill in the gap and steady the transom. Not perfect, but it helped.
Time to bevel the outboard edges of the bottom planks.
The top planks has not been beveled, the lower planks beveled.
I next soaked the bottom planks in hot water for about ten minutes, then formed them on the building board.
Following the instructions to have the fore ends of the bottom planks touching, with a slight overhang at the stern, I left the bottom planks to dry.
009 Bottom Planks soaked and drying on form 2.jpg010 Bottom Planks soaked and drying on form 3.jpg
Once the bottom planks were dry, I sanded both sides of each plank with progressively finer sanding boards, until they were very smooth to the touch. Each were then sealed, and held to the building board again, to ensure they maintained their bend. I repeated the sanding and sealing one more time, then one final sanding with a 220/240 sanding board. Once finally dry, I glued the two boards to the stem and transom.
UPDATE: Due to there being some spring in the bottom planks, still, the transom and its brace kept popping out of its slot. To remedy, I placed clamps at the end of the board, effectively wedging in the transom and its brace. To maintain the alignment of the stern knee to where the keel plank would lay (I forgot to take a picture) I clamped a toothpick (cocktail stick) to the inboard side of the transom. About 3/4" to 1" stood up above the bottom planks. Using a rubber band around the toothpick, and pulling it sternward, I used it as a lever to align the transom to the point where the bottom of the knee was level with the bottoms of the bottom planks.
I repeated the soaking, sanding, and sealing process to the keel plank, and secured it to the building board to dry.
An issue I noted in several Pram builds was the gap between the keel plank and the bottom of the transom. I do not know if the tab at the bottom of the transom is too short, or it was beveled too much. I cut a shim from the scrap wood from the planking sheet, to fit the width of the gap, and as deep as the transom front to back, and glued in place. I believe once the pad is placed for the lower gudgeon, the shim should be invisible.
Before I glue down the keel plank, I will sand the shim flush to the surface of the bottom planks. When I trim the aft ends of the bottom and keel planks the shim will get sanded flush with the ends of the planks and transom.
The keel plank glued to the bottom planks.
With the keel plank drying, you can see how the shim fills the gap between the transom tab and the plank.
I thought I had sanded the shim enough. The warp of the keel plank says otherwise. I think a little filler may be in store once the outboard transom has been finished flush.
This weekend I will start the rest of the planking.
The metal fabricating will have to wait until my hip heals a bit more. I need to clear all of the auto parts and associated sundry from my work bench. I am currently using a portable work table in my dining room. Not enough room to work with soldering irons and such.
More work than expected working on ONE garboard strake. Then, isn't that always the case, with something?
Lining up the starboard garboard plank I found the bow and stern transom edges needed some sanding. Each had 'shoulders' beyond the outboard edges of the bottom planks.
Blue: Before sanding; Red: After sanding
Bow transom after sanding
015B Sanding the Bow Transom to batter match the incoming Garboard Planks.jpg
Next up was making the rabbets on the lower ends of the garboard plank. I measured out the 'one foot' scale length, made stop cuts along the length and end of the rabbet. Using a #11 blade and a chisel point I trimmed away the excess. After the picture was taken I did a little more scraping with the chisel blade to deepen the rabbet.
016 Rabbets Marked on Garboard Planks.jpg017 Rabbets Cut from Garboard Planks.jpg
Besides the transoms needing some sanding to match the garboard planks, the build board forms also needed some sanding.
The sanding was just enough to maintain the angle of the edge, but also just enough to continue the slope of the beveled bottom plank along the slope of the form.
The garboard plank soaked and drying on the build board.
I checked the alignment at the stern and bow transoms to see how the rabbets worked out. I was quite pleased that the alignment was pretty good on the first try.
Not perfect, but pretty good. No doubt with more experience I will get it better in the future.
More carpentry skills to use. Aligning the bow and stern ends of the garboard plank to the transoms I found the bottom edge of the plank to stand very proud from the bottom plank.
Time to break out the mini-plane and do some trimming.
With the garboard plank aligned on the form, I made a pencil line from the inside to mark the outer edge of the bottom plank. I knew this was not the destination of the trimming, but a reference line to guide my hand. After several back and forth passes with the plane and checking the alignment, I finally got to a point where I was satisfied with the rough edge of the plank. I then sanded the edge of the garboard plank smooth, as well as matching the contour of the bevel line on the bottom plank.
Satisfied with the final outcome, time to sand the surfaces and seal the plank. The sanding process straightened out the plank a bit. The sealer gave the plank enough flexibility that I was able to bend it to the form, clamp it, and wait for it to dry. I will repeat this once or twice more until the surface is as desired. Then on to the port side garboard plank. Finally, rinse and repeat for the second strake planks and the sheer planks.
View attachment 539655View attachment 539656
You are really going the extra mile with the planking. I think way beyond what most of us did. I am sure it will pay off!
Thanks.
I am not a perfectionist, but when I commit I go 110%.
Over 20 years (late 60s to early 90s) of model building, about a dozen years of theatrical set and lighting design and building, I am very much into the verisimilitude of making things look like their real-life counterparts.
Cheers
Your story sounded like a full size building experience. - trim here, sand a bit there, make it fit at the joints…
“Next one we build, remember to leave that plank a bit full to give us some wiggle room”
- next one is always better, and easier.
J
Garboard plank glued to bottom plank.
Dry fitting the garboard plank by hand, after trimming, it was looking good, the proud edge not so pronounced. After gluing the plank in place the plank was standing proud in two places. Will need to carefully trim them down.
While I was waiting for the garboard plank to dry on the form, before gluing it in place, I started work on other components.
I started with the dagger board case. The spacer ends for the case were laser cut across the grain, instead of with the grain. Made them very fragile. Fortunately I was able to sand off the char from the case ends without causing any damage.
Note the grain of the case side and ends in the same direction. The case would be much sturdier if the case ends had the grain going across the side piece grains. I considered fabricating new ends, but decided against it, since I was able to sand them without damage.
I cleaned up the dagger board.
I first cleaned up all of the char. Next I marked the reverse side of the board to match the guide for the bevel on the laser etched side.
28 Dagger board laser marked side.jpg28a Dagger board pencil marked side.jpg
Laser etch on the left, pencil mark on the right.
I sanded down the bevel, on both side of the board. When I was close to where I wanted it to finally be finished, I started sanding down both faces of the board. Many fittings of the board into the case to ensure a smooth passage in and out. Once I have sealed and painted the board, we'll see if I sanded enough. If not, more sanding.
Here is the dagger board with the components for the board stop. I plan on making a lid for the dagger board case, for when the dagger board is not deployed. (Have not decided which way to finally display the pram, when completed.)
The assembled dagger board. The stop still needs to be trimmed and shaped.
I figured, while I was at it, what else could I work on, while the garboard plank glue dried?
Something simple, the mast step. I glued the mast step to the mast rest. I will sand to shape once the glue is well cured.
This is another case of where, in hindsight, I should have fabricated my own mast step and rest. The grain is going in the wrong direction.
Finally, a question for our knowledgeable readers: The dagger board has three holes, aligned vertically, and evenly spaced. I am not a sailor, but, I grew up on the Long Island Sound and was exposed to many types of power and sail boats. Can I assume the holes had a pintle that could be inserted in these holes to give the dagger board different depths, as needed, and appropriate for the sailing conditions? If I am correct, would the pintle have been most likely attached to the dagger board case with a line or chain, or either?
Edit: I did a little digging and found some answers, but not all. The holes are indeed for setting the depth of the dagger board. However, I have yet to find a satisfactory answer about actually setting the depth. Every answer, so far, indicates passing a line through the hole, knotting it, and tying it off, to set the depth. I think that is an okay answer, but unsatisfactory. It seems to me that such an arrangement is way too slow to change if the board depth needs to be adjusted quickly, such as the wind picking up suddenly.
Cheers
Great work, and hope the hip work heals up quickly so you can get back to full operations ASAP.
Now you can say your mostly original with a few after market upgrades!:)
Thanks.
I definitely have a few upgrades: Both knees replaced, with the left knee replacement "revised", i.e., a damaged prosthesis (that's another story) replaced with a newer much more extensive one, and now the hip. The right hip is expected to need replacement in about a year or two. I am hoping for two.
View attachment 539962View attachment 539963
Cheers
Looking great!
With the Dagger board case ends, you may consider using thin CA to soak into the wood to strengthen them.
Rob
...and, we proceed...
Process for adding the Second Strake Planks and Sheer Planks pretty much the same as the previous planks: Check alignment, sand the bevel, soak, dry on form, cut rabbets, sand and polish, seal, dry on form again, glue to hull.
I began to see a pattern, regarding the rabbets. I was not getting smooth transitions along the rabbets from the ends of the planks as the plank progressed along the prior plank. I found cutting the rabbets pretty easy. Cut in stops, then used a chisel blade to slowly shave off a little at a time until I was happy with the depth of the rabbet. What I began to realize is the rabbet should not only slope toward the edge of the plank, but also slope deeper as the rabbet progressed to the end of the plank and shallow as the rabbet moves away from the plank end. Something to keep in my mental catalogue of things to remember in the future.
I felt I had been doing a good job in spacing and aligning each successive set of planks. Measurements were all with a millimeter. My transom says other wise. On closer inspection I see the upper and lower transom are NOT aligned properly. Oops.
Like I said, I am pretty happy with the spacing and alignment.
Progressing with the second strake planks and the sheer planks, I did not have to plane the lower edges of the planks to ensure appropriate alignment of the lower edges with the bevel edges of the planks below them.
Second strake planks in place. Coming together, starting to look like a boat.
With all of the planks in place, I am pretty pleased with how they lined up at each end.
Sorry the bow transom is out of focus. What I discovered (for what I considered too late to fix) is the keel plank did not dry aligned quite on center. I have a little filling and more sanding to do on the bow, to fill those voids.
Other than the earlier comment about the transom, I am happy with the alignment of the planks. I am also please that the shim I placed between the keel plank and the transom is doing the job.
When the time comes to trim off the excess on the bow and stern transoms, I will need to work a new arc across the stern, to match the sheer planks.
I am sure that I did not take too much off of the stern transom tab, causing the space that needed the shim. A result is the stern knee is 'hanging' a bit over the bottom of the boat. Have not decided whether to insert a shim, fill with a filler, or leave it alone. Will depend on how the stern sheets mask the sin.
Skeg and bilge keels in place.
Needed to do quite a bit of sanding at the stern end of the skeg, to have it match the curve of the hull. I had to sand the fore and aft ends of the bilge keels to do the same along the garboard planks. The ends already thin made me nervous, but I managed.
Dagger board case installed.
Referencing other build logs, I went with placing the case forward of the, seemingly notorious, long slot for the case supports. I created a shim to fill the resulting gap, that also doubled to wedge the case in place.
Another note to self: If I am going to jump ahead to get some other fabrication done, I better read ALL of the instructions carefully, first. The dagger board case requires two lengths of 3/32" square pieces to create the dagger board stop. What I did not realize was the inwales ALSO used the same 3/32" square strips. What the instructions failed to mention was the dagger board stop and the inwales share the same source material. IF I had cut the two pieces ONE from the each of the two strips, I would have enough to make the inwales, and the dagger board stop. Another Oops.
I am now waiting for delivery of some 3/32" square strips, and other material, so I can make the inwales.
So, now, while waiting on the inwale strips, I can start on the bottom frames and quarter knees. Still need to figure out how to use the tick strips, as only one is clearly illustrated. The seat and thwart frames will need to wait until the inwales are attached.
Cheers
And we continue...
I covered this a bit earlier: The planks were not lining up amidships as desired. In hindsight, the build frame was probably not secure enough at the bow and stern. As a result the boat ran a bit narrow. I measured the beam, which ended up about a quarter inch (1/4") too narrow. This made the exposed planks a bit shy, causing some alignment issues with the frames.
In a few places I could make some compensation by judicious sanding of some of the inner faces. In other cases I needed to cut down the frames, plus the midships knees to make the fit.
So, onwards...
The Dagger Board Case installed, and shimmed.
Here are the Forward Seat Frames. The top one is cut down (too much I discovered), and the bottom one marked for cutting.
I adjusted the cut on the second frame, taking a bit less off, and it worked better than the first.
Installation of the Floor Board Cleats. Cut to length, sanded smooth and the edges eased. They look good.
It took a few tries to clamp the cleats down, without having them slide out of position.
I made the mistakes of using clamps with the side frames. Even when sanded properly for the hull side angles, a few slid. One or two egregiously. Vinegar to the rescue.
Frames and cleats in place.
Time to apply the vinegar to the seat frame. (Top center.)
Applied a liberal dose of vinegar. Worked the frame out of place after about a minute of soaking.
NOTE: The Stern Transom is not lined up properly, as noted in an earlier post: the top and bottom are not as square as they should be. That, coupled with the narrower beam, bow and stern ends of the planks are misaligned slightly. I shaved down the transom as best I could to give some semblance of symmetry. Eh. On closer inspection, I found that the bow and stern knees were at different angles. That is, the two bow knees were not symmetrical, and the two stern knees were not symmetrical. Not sure why, but a liberal dosing of vinegar on the higher knees failed to loosen them. I was not going to risk damaging the work so far by overdoing a fix. I will have to live with it. No doubt I will be the only one who will ever notice.
Rowlock pads were next. I did not have any issue with sizing them, shaving them to shape, and finally sanding them and drilling the oar lock post holes.
Note where I removed the worst offending seat frame.
I measured out the scale 9" for each pad, and divided them each into thirds. I did this one at a time, leaving them connected to the full length strip. At the 9" mark, I used my #11 blade to create a stop cut for the bevel. From the 3" mark nearest the stop cut, I applied a chisel point, with the bevel side down, and slowly shaved off a little at a time, until the low end of the bevel was about two-thirds (2/3rds) of the way through. I then reversed the procedure beginning with the three inch mark closest to the end of the strip.
Once I was satisfied with the profile, I used the chisel point to finish the cut through the strip where the stop cut was placed. I repeated this three more times to completed the four rowlock pads. I then lightly sanded each piece. Before gluing the rowlock pads to the inwales, I used a fine point probe to mark where I would need to drill through for the oar locks.
Finally, I glued the rowlock pads to inwales. I then drilled the holes for the oar locks, making sure I did not drill into the planks, per the instructions.
Installation of the Midship Thwart Knees.
As with the frames, due to the narrower hull, everything was being shifted up. I needed to trim off the bottoms of the knees to allow the Midship Thwart to fit in place.
After the rowlock pads I THEN made the slots for the Chain Plates. I found that the tip of my #15 narrow saw blade did not fit in the hole made by the #72 bit. Using the #72 bit, I drilled out three more holes, in a line, within the 2" scale description. This made it much easier to insert the tip of the saw blade. I then proceeded to shape the slots per the instructions.
Finally ready for primer.
Sanding, sealing, sanding, sealing,...
Primer applied.
That will be the LAST time I use rattle can primer for the interior surfaces. Lack of control, and the occasional 'burp' made a mess. Had to wipe down and wipe off some excess primer. After waiting 24 hours to fully dry, I sanded down all of the ugly wipe marks, as best I could, with the sanding tools I had. Once cleaned up, I manually applied primer to any area exposed by the sanding. Them lightly sanded again.
As we all know, primer exposes all of the sins. No different here.
The stern transom still had the trim line. With the issues I enumerated earlier, the planking ran higher than desired.
Time to apply filler. I used Minwax Stainable Wood Filler. The wood filler is very coarse. I had my fingers crossed that the carrier in the filler wood fill the gaps, once I sanded away the grit.
Once I sanded down the filler, and re-primed, I found the filler carrier indeed filled the gaps once the grit was sanded off.
I need to do some more sanding of the keel plank.
I was finally ready to paint this baby. I do not like the dark red supplied for the model. I decided to go with the Model Shipways True Blue, MS 4964. I am happy with the result. Still dark like the red, but 'brighter' a bit.
I believe the model looks better with the rub rail painted the interior color. Adds a bit of 'body' to the sides.
I cobbled together a Dagger Board Case Cap, as suggested in the directions. I think it will ad a nice detail to the model.
The cap, the dagger board, and the rudder have their first two coats of paint. Need to sand them, and give the final coats.
The dagger board has three holes for adjusting the depth. These are not addressed in the instructions (at least not that I saw). I am planning on manufacturing a pin on either a short chain or rope, that would be attached to the case.
The instructions mention the installation of brass rub/wear strips on the Skeg and Bilge Keels. I have thin brass sheet which I will cut thin strips from, to apply to the skeg and bilge keels.
Time now to paint the hull.
When the outer hull painting is complete, then on to the floor boards, thwarts and sheets.
Then, the real fun begins: Assembling the tiller, rigging up the rudder, and finally the mast and rigging.
Arghhhh!!
Many build logs as well as the instructions note to ensure the dagger board is sanded thin enough to clear the case, once painted.
My dagger board cleared the case quite smoothly, unpainted. I went to test the clearance after painting the dagger board. It slid in about an inch before getting stuck. I struggled to extricate the board, carefully, but, alas, it wasn't to be...
I straightened out the deck as best I could, reglued the case, then superglued the hull, where split. Will sand and touch up paint.
I am reconsidering my display plans. I may insert the case cover and leave the board on the floor boards. I haven't decided whether to display with or without the sail; depends on how well I fabricate the sail. We'll see.
