RMS Titanic - Trumpeter 1/200
I've seen all the videos, but unfortunately I hosed the parts up... I'll re-attempt though. Still working on the inner decks, easy primer into the PE work needed later.
Lovely work by yourself too Big Jake! You should start the 1/200 kit!
I've worked on A deck structures, and putting in windows, there were 44 of one size... that's a lot of fiddling, but still lits of fidling left to accomplish!
I'll add photos later!
Need more medium CA...
Anyway, the white glue (using Mod Podge gloss), works a charm so far. Easier clean up, and does wonders in sticking small pieces of PE to plastic.
A deck structures:
One door missing, the handrails are a bitch to get/keep straight... Thankfully this will be behind a bullwark on A deck, 1 deck below the boat deck.
Some of these windows have the "stained glass" from the KA set... Micro cutting with very fine scissors on slippery plastic... NOT easy, but whatever! Looks really cool
The most time consuming part of any, is cutting the PE from the fret, cutting the nubs, then filing the nubs... There are 44 of the smallest windows on the longest structure shown... So there are TONS of windows. But, I think this is an excellent primer to more advanced warships, because even though there is a dearth of PE parts, most are easy subassemblies requiring a single fold, if any. Or a gentle curve. So there are thousands of parts, but they're relatively easy to affix!
I'll probably eat those words later.
Cheers
H.
Besoin de plus de CA moyen...
Quoi qu'il en soit, la colle blanche (à base de Mod Podge brillant) fonctionne à merveille jusqu'à présent. Elle est plus facile à nettoyer et fait des merveilles pour coller de petits morceaux de polyéthylène sur du plastique.
Une structure de pont :
Il manque une porte, les rampes sont difficiles à maintenir droites... Heureusement, ce sera derrière un mur sur le pont A, 1 pont en dessous du pont des bateaux.
Certaines de ces fenêtres présentent les vitraux du coffret KA… Micro-découpe avec des ciseaux très fins sur du plastique glissant… Pas facile, mais bon ! C'est vraiment cool.
La partie la plus chronophage est la découpe du PE de la frette, la découpe des bosses, puis le limage… Il y a 44 des plus petites fenêtres sur la plus longue structure illustrée… Il y a donc des tonnes de fenêtres. Mais je pense que c'est une excellente introduction aux navires de guerre plus avancés, car même si les pièces en PE sont rares, la plupart sont des sous-assemblages simples nécessitant un seul pli, voire aucun. Ou une légère courbure. Il y a donc des milliers de pièces, mais elles sont relativement faciles à assembler !
Je mangerai probablement ces mots plus tard.
Acclamations
H.
Bonjour, Quelles sont les colles que vous employez pour coller les fenêtres et autres. Merci pour votre réponse..
Françis
A deck structures:
Cheers
H.
If you are installing the scale decks, make sure your doors are not too low on the superstructure. I had to take all my doors off and start again.
A deck structures:
Cheers
H.
Hey Winnie,
Looking good mate. That's a lot of work. I need to get back to mine full time again; it's been too long. Would love a closer shot of the stained glass windows. The KA inserts seem to stand out quite well.
Cheers,
Steve
Hello Winnie,
great progress sir. I’m glad to see you didn’t rely on the self adhesive decking by itself. The white carpenters wood glue will ensure a proper bond.
I also noticed they are selling a Titanic engine room kit in 1/200 scale on eBay. There’s so many great aftermarket options for this model.
Hello Winnie,
Hey Brian,
I read up on that kit, and it's made to complement the Trumpy Titanic. You can apparently display them alongside each other and get an amazing insight to the inner workings of the beast. :-) Fathers Day gift? Meh, probably not. A bit beyond my kids savings accounts.
Hey Brian,
I wonder whether someone could potentially do a cut away of the ships hull on one side, and install this engine room inside the actual model. Kind of like a cross section model.
Oh my, Brian. That sounds like a challenge. :) In theory, it should be possible, as they are both the exact same scale. What a display piece that would mate.
Wow this is outstanding work.
Words can't really express the level of detail and devotion one has put into this model.
Here is the first of the few "after market" Items.
Ordered drill bits from Amazon.ca, these are 1, 1.5, 2, 2.5 and 3mm and will compliment the Fibre Optic strands ordered from LighthouseLED.com
I thought the set was 5 bits each, but it was 50, 10 of each so I'm a happy camper. they were $17 Canadian including shipping so one of the cheaper parts of this build!
These are sold on Temu, I purchased the same set for £2.50 and the quality is far better than I expected as they worked well in steel, more than happy.
Hello Winnie,
Bryan,
Got curious - saw the listing on Ebay - wow!! - 24 images details way beyond amazing. Not intended to
be inserted into ship, but as an outside display - awesome indeed. couple more images
The cutaway ship... WOW. Had some other expletives there!
The engine set has a few reviews online, and it'd be fun, but I have other ships to build too!!
Got a week off, hope to have a few hours at the bench!
