How do you keep the CA bottle from getting clogged? I'm using Bob Smith Industries Insta-Cure+™
Try using the extended tips available on ebay etc very cheap in larger packs rather than 5 or 10-packs offered by hobby shops. The glue will dry in the tip sealing the bottle, then when you next use it, just snip the end off. I use BSI odourless.How do you keep the CA bottle from getting clogged? I'm using Bob Smith Industries Insta-Cure+™
I used the top of a coffee can or peanut can or something with a flexible plastic lid. You can peel dried epoxy right off of it.This only works well with the 2 oz bottles, the smaller ones are usually too stiff, but if you "pre-squeeze" the bottle a little before tipping it to your work, then place the drop of glue. As you release the pressure on the bottle, the vacuum inside will suck the adhesive back up through the nozzle into the bottle. Then, just to be sure, hold a paper towel or tissue above the nozzle with the bottle upright and give it a couple of quick, light squeezes to clear the nozzle.
I use the thin nozzle extensions for the super thin CA, but for the thicker variants, I usually squeeze some out onto waxed paper and use a toothpick - again, using the pre-squeeze method. I take a large piece of waxed paper and pre-cut squares about 2" x 2", stack them up and put a staple near one edge. This give you a "pad" of waxed paper to put CA on or to mix a small batch of epoxy, mix a little paint, etc. Rip it off, discard it and you have a fresh sheet ready for the next batch.
Also, I advise against sucking any CA back up into the bottle as it can have debris in it and I believe accelerate it hardening in the bottle.
