A6M Zero
It is a very unique aircraft…I’m enjoying the build.The P-39 was a great plane. Our guys didn't like it because they removed the supercharger before it went into production. As a result, it's high altitude performance suffered a lot. However, the Russians loved it because they used it for ground support. It stayed at lower altitudes with them and the plane excelled ! It is the only plane that I'm aware of where more than half of them that we built were sent out on lend-lease.
Incidentally, since the the engine was not up front, it enabled 2 major changes which helped a lot. first, it was able to have a nose wheel which greatly helped ground handling. Secondly, enabled the design to have a much more streamlined design to help performance. Interestingly, P-39's won quite a few air races after the war was over.![]()
Thanks Russ!The panel lines and aging on your "Peashooter" came out great!
