Me too.You have the later blue kit, with sails, i have the red kit, so will have to make my own patterns (eventually!).You are doing very nicely.
You can see my captain is not pleased with the progress on his Hussard!
You are doing very well, looks great ! Do not worry about mine, i am working to original 1860's plans, not to artesania's, so it looks very different from any of the kits ! I have recut the entire hull shape and changed the scale to 1:55 in order to use the kit wood, and i have added a lot of blocks under the deck edge to anchor shroud lines and bulwark supports to. That's just my methodology. I will probably do a build log when i have finished my present builds.Yes mine is the blue kit and looking at your model seems very different, I am still making some progress each day although with the rigging it is geting complicated ??
thanks for that, I shall have a look. I don't really want a river boat but an early sea going paddel steamer/sail boatThere is a build log going for L'Orenoque (Mamoli)by the Gavel in the kit forum, it would be contempory with your Hussard, or there is the Harriet Lane (Model Shipways) and a new one by Billings, the Hjejlen, all are sidewheelers . or the Texas riverboats , tailwheelers. Most of the arctic exploration ships are mixed screw/sail , Terror, Endurance, (occre) or the old Pourquoi Pas by Constructo if you can find it. there are quite a few in this class in kit form. Depends what you can find in Aus i suppose.
