Glue
Quick is a relative term. PVA wood glue is considered non-toxic and sets enough to hold parts together, if they are properly made and fitted, in a minute or less. For some, this may not be considered quick. Many probably would consider "quick" and "building ship models" an oxymoron. :)
Depending on your application, you may want to consider UV setting glue. Unlike CA it will not stick to you. The good side it that it will not stick to anything but then will set instantly when exposed to a UV light. (UV flashlights are easy to get on Amazon). I most often use it when setting PE pieces into place such as railing on ships. The down side is that it is not as strong as CA and has to be used in an area where it can be exposed to the UV.
Rob
I use Aleene’s Tacky Glue all the time. I put the cap back on and store it upside down in an unused deep coffee cup.
BSI odourless CA.
I second this. I was somewhat skeptical when I first read of this particular product, but given my sensitivity to CA glue and several recommendations from other forum members, I gave it a shot. I'm truly amazed that it works well (like any CA), but also that I have absolutely zero allergic reaction to it. It's been a life changing product for me and my pursuit of model building.
Rob
So, if only UV light sets the glue, and the glue is between to tight fitting pieces, how does the UV light get between the parts? ROTF
I believe the UV acts as a catalyst. So if there is an exposed area of glue that extends under the part the reaction starts at the exposed area and propagates into the area not exposed to the UV. I am not certain of this to be honest.
However the reaction occurs, it does work and will not adhere to anything until it is exposed to the UV light. I find this property very helpful when setting small parts.
Can anyone suggest a good "Quick setting, non-toxic" glue?
Thank you
Depends on "how quick". For wooden construction I use Gorilla glue. For working with styrene plastic, I use Tamaya liquid solvent, but is is toxic. But it is the best and takes hold fast. Better than Testors in my opinion.
I hope you mean Gorilla's PVA glue, because their "Original" is a polyurethane and not at all suitable for model construction. If you do mean the original, then neither it, nor the Tamaya fall into the "non-toxic" category the OP was asking about.
Most any PVA (Elmers Glue All, Titebond II, Tacky glue) are considered non-toxic, but not necessarily "quick setting". I think you might find the two somewhat mutually exclusive.
Yes, sorry for the misstatement. I meant it sets quicker,but not like super glue.
