Formula for ballast needed?
  • Thread starter Thread starter RFitz
  • Watchers Watchers 8
for our model use, I'll bet a cheap student gizmo is still overkill.
i just thought it would be interesting to see how its used.
You are absolutely correct. It's not likely that a modeler would require a professional drafting instrument of any kind. In most instances the student level instruments get the job done if used with care. The one exception I would note, however, would be instruments which are marked with scales. The scaling affects the accuracy. There's a big difference between the scale on a classic machine engraved rule and a cast plastic one!
Actually, there's a trick of the trade for taking accurate readings with a planimeter. It's critical when tracing the edge of the irregular plane with a planimeter that you keep the cursor exactly on the edge line. While this is easier with planimeters that have good magnifying "bullseye" cursors, it is still a tedious exercise, and a shake of the hand can cause an error. To minimize the error, one can take repeated measurements, five or ten being quite adequate, I'd think. Any measurement which is obviously greatly erroneous can be discarded, and then the total area of the measurements retained thereafter is then divided by the number of measurements retained to yield an average measurement which, in theory, at least, increases the accuracy.
I suppose I should also mention that anybody who may be considering acquiring a planimeter should identify the type of scale measurements they want to obtain. There are a lot of different options, the most obvious being metric or imperial measurements and the range of measurement, e.g. feet, yards, meters, etc. Some planimeters can be set for a wide variety of measurements, while others are limited.
Another caveat about planimeters, and any measurements relevant to period ship modeling, is that the definition of measurements, for instance, the foot, was not internationally standardized until 1959! (Yes, 1959. Surprised me, too.) Particularly in 17th and 18th Century Europe, the length of a "foot," varied considerably, with many nations, and, indeed, cities within nations, having their own definition of the length of a foot. As seen from the chart below, for example, in an Amsterdam shipyard, a "foot" was 283.133mm, while in a Rotterdam shipyard, a "foot" was 312.43mm, and a foot was 296.9mm in Sweden, and 305.287mm in Scotland! There were 9 different "foot" measurements for various cities in the Netherlands and 21 different "foots" in Germany and on top of all that confusion, some changed from time to time. See: https://en.wikipedia.org/wiki/Foot_(unit)
Thus, if you are trying to calculate the ballast required for a given ship, you will have to begin by identifying the measurement system used to describe its size and then translate that to present day standards from which you can calculate the ballast needed accurately. If you don't do this, your ballast calculation can be somewhat off the mark. This circumstance is also applicable to all scale measurements. A ship that is 150 feet long could easily be over or under by several feet in length if the actual contemporary measurement standards aren't taken into account.
ViennaAustriaWiener Fuß316.102[46][37]
TyrolAustriaFuß334.12[39]
Ypres (Ieper)Belgiumvoet273.8[50]
Bruges/BruggeBelgiumvoet274.3[50]
BrusselsBelgiumvoet275.75[50]
HainautBelgiumpied293.39[43]
LiègeBelgiumpied294.70[43]
KortrijkBelgiumvoet297.6[50]
AalstBelgiumvoet277.2[50]
MechelenBelgiumvoet278.0[50]
LeuvenBelgiumvoet285.5[50]
TournaiBelgiumpied297.77[43]
AntwerpBelgiumvoet286.8[50]
ChinaChinatradesman's foot338.3[51]
ChinaChinamathematician's foot333.2[51]
ChinaChinabuilder's foot322.8[51]
ChinaChinasurveyor's foot319.5[51]
MoraviaCzech Republicstopa295.95[39]
PragueCzech Republicstopa296.4[45](1851) Bohemian foot or shoe
301.7[40](1759) Quoted as "11 pouces⁠1+
3/4​
lignes"[Notes 1]
DenmarkDenmarkfod313.85[46]Until 1835, thereafter the Prussian foot
330.5[40](1759) Quoted as "⁠2+
1/2​
lignes larger than the pied [of Paris]"[Notes 1]
FranceFrancepied du roi324.84[52][Notes 2]
AngoulêmeFrancepied d'Angoulême347.008[53]
Bordeaux (urban)Francepied de ville de Bordeaux343.606[53]
Bordeaux (rural)Francepied de terre de Bordeaux357.214[53]
StrasbourgFrancepied de Strasbourg294.95[53]
WürttembergGermanyFuß286.49[39]
HanoverGermanyFuß292.10[39]
AugsburgGermanyrömischer Fuß296.17[44]
NurembergGermanyFuß303.75[44]
Meiningen-HildburghausenGermanyFuß303.95[39]
OldenburgGermanyrömischer Fuß296.41[39]
WeimarGermanyFuß281.98[39]
LübeckGermanyFuß287.62[46]
AschaffenburgGermanyFuß287.5[43]
DarmstadtGermanyFuß287.6[43]Until 1818, thereafter the Hessen "metric foot"
BremenGermanyFuß289.35[46]
RhinelandGermanyFuß313.7[51]
BerlinGermanyFuß309.6[51]
HamburgGermanyFuß286.8[51]
BavariaGermanyFuß291.86[39]
AachenGermanyFuß282.1[44]
LeipzigGermanyFuß282.67[39]
DresdenGermanyFuß283.11[39]
SaxonyGermanyFuß283.19[46]
PrussiaGermany, Poland, Russia etc.Rheinfuß313.85[46]
Frankfurt am MainGermanyFuß284.61[39]
Venice & LombardyItaly347.73[39]
TurinItaly323.1[51]
RomeItalypiede romano297.896[53]
RigaLatviapēda274.1[51]
MaltaMaltapied283.7[51]
UtrechtNetherlandsvoet272.8[51]
AmsterdamNetherlandsvoet283.133[42]Divided into 11 duimen (inches, lit. 'thumbs')
Honsbossche en Rijpse [nl]Netherlandsvoet285.0[42]
's-HertogenboschNetherlandsvoet287.0[42]
GelderlandNetherlandsvoet292.0[42]
Bloois (Zeeland)Netherlandsvoet301.0[42]
SchouwNetherlandsvoet311.0[42]
RotterdamNetherlandsvoet312.43[43]
RijnlandNetherlandsvoet314.858[42]
NorwayNorwayfot313.75[54](1824–1835)[Notes 3] Thereafter as for Sweden.
WarsawPolandstopa297.8[55]Until 1819
288.0[43](From 1819) Polish stopa
LisbonPortugal330.0[44](From 1835)[Notes 4]
South AfricaSouth AfricaCape foot314.858[56]Originally equal to the Rijnland foot; redefined as 1.033 English feet in 1859.
Burgos and CastileSpainpie de Burgos/
Castellano
278.6[40](1759) Quoted as "122.43 lignes"[Notes 1]
ToledoSpainpie279.0[40](1759) Quoted as "10 pouces 3.7 lignes"[Notes 1]
SwedenSwedenfot296.9[46]= 12 tum (inches). The Swedish fot was also used in Finland (jalka).
ZürichSwitzerland300.0[51]
GaliciaUkraine, Polandstopa galicyjska296.96[43]Part of Austria–Hungary before World War I
ScotlandUnited Kingdom305.287[57][Notes 5]
