Excellent tip. I'm new to milling, so this will prove very useful.
I use my milling machine a lot. It would be helpful if you could review my build log thoroughly.Excellent tip. I'm new to milling, so this will prove very useful.
Thank you!Another outstanding job!
Thank you Paul!This is nice work, Mustafa!
Thank you Peter.Lovely, clean, precise work!
Thank you. Yes, it would have looked nicer if I had done as you said. My laziness.I really like level of detail in this mast piece. It would be even better if platform was made of multi glued boards rather than a single piece.
Thank you so much Grant!Good morning Mustafa. Fabulous detail and accuracy- really good stuff. Cheers Grant
Thank you so much my friend!Dear Master, you should be proud of yourself... simply magnificent
so much better looking than the setup in the plans.I'm still working on the masts. I've finished the chafing fish on all three masts and started mounting the iron bands. I cut the iron bands from 0.3 mm brass sheet and glued in place with CA.
