Royal Louis 1/200 Heller
Hello all!
hope you're having a good day!
I am currently refurbishing the Royal Louis Model I assembled almost 20 years ago!
I received the very good spare parts from HisModel online shop and I must confess that l got scared a little seeing hundreds of blocks and deadeyes in front of me ^^ but I am very with the quality of the parts I received.
I started back in early September painting using China Black ink some of the natural ropes I also got on that shop online20250913.jpg
My first Blocks on the ship!
I then started to remove the sails I sew back then, as you could tell they were not that great even thought I did the best I could.
I then painted in Black the yards, just like it was in the past in history.
Some more blocks!
I started assembling the large ones just to get use to it... and it is not as easy as it seems ahah
You are still seeing the old ropes, I hadn't removed then back then
Attaching a little chain left from some other kits to the rudder
The "crane" was an very difficult moment for me but I am happy with the way it looks.. By the way I have since updated one end of the crane, under the first basket (thank you Radimir From HisModel for the feedback).20250930.jpg
Trying shrouds with thicker vertical ropes and thinner horizontal ones. I tried in both colours without the Heller roping frame machine but the result isn't great.
I was also told that at my small scale 1:200, it would be probably best to keep the shrouds in Black.
The bottom shrouds of the rear Mast..
ropes through deadeyes are not glued yet so I can tighten them when on the ship
I attached some rope to the canons at the back of them till the railings20251064.jpg
I built some triangles to pack the canon balls using some tea steerers, and railing from other heller kits for the edges of the triangles.
The canon balls are from a famous Chinese online shop! Hope this is convincing
I also used some spare plastic parts to 20251063.jpgbuild a kitchen grill, the kitchen chimney and the chicken coop!
The chimney is made of mettalic left over of PE parts ^^
Hello
You've made a very good decision to reassemble your model. Radek has top quality pulleys and deadeyes.
Unfortunetly I don't agree on deadyes diameter, they're little oversized. I've made the same mistake on my model and many others.
I don't know whether you would like to hear my advice or on what stage you're at. I can point on some parts that could bring
your model more to historical look
The deadyes are little too big. I had oportunity to make model with correct size ones, but I couldn't tie them and used bigger. Now from time
perspective if you have patience place little smaller then what is shown in most build logs. It is a minor detail, but one of more important.
The smaller, the better, but I doubt you will find them in any online store
Those clamps on dead eyes are also too big. I wouldn't use them at all. You can try to solder chain as I did partialy, but there is easier method.
You can fake it wit thread soked in CA glue. Make a loop on desired height and then soke the thread to stiffen it.
Another mistake I made on my model-the
chain was inserted too low it should be on black belt above. My colleague on the Polish forum did something similar in Le Superbe 1/150
Bobstays- that conection on two deadeys with hull. Same thing I should get rid of hook and use a 1/1,5mm ring instead of dead eyes. Also I used pre drilled holes in hull. I should fix the holes and make a much smaller loops little above existing ones in black belt
Those build logs are top notch, I used them as inspiration, maybe you will reach that level as I couldn't
Some lovely work there..
Thank you :
Hello
Thank you so much Wojta for the time you spent revieving my posts and your advice. I agree the dead eyes are a little too big but I already fit them all so I might try to fit them as it is to see how it looks like. But I think you are right I will change them.
Oh yes I also have boukmarked this stunning 74 Guns le superbe but I don't think I am capable of what he did.
I didn't know about the second link thank you so much again
I will change my hooks thank you
I spent some time last week repainting the hull
Waterline in Black as it used to the case
I am painting the top railings in Black
I have then painted again in White the hull have sanded it
And to finish I have painted the top rear of the hull in blue- I have checked paintings and models and no French ships didn't have this part painted...
As I have used the Heller Shroud frame machine to glue with CA some ropes
So that I could de-assemble the gunport cover, glue the ropes and re-assemble it so it looks like the gunport cover has its manoeuvring rope!20251126.jpg
And finally what I did over the last couple of days was repainting the Stern.
My Stern was blue and gold but this choice of colour is anachronistic for a ship launched in 1780.
I tried to sum up my researches below:
1700 and before: gold and blue
From 1770 onwards: black and yellow of Naples - the gold became too expensive for the shipyards.
There is actually one and only painting of the Ship painted during the révolution in 1795: the Stern is yellow and black like other ships of the time
I am thinking of painting the ship before the révolution so my rationale is as following:
- gold should be replaced by yellow - gold was only used if only for coat of arms
- not much blue left (perhaps a little since Royal Louis and Soleil Royal are ships that are supposed to stand out from the other ships of the navy)
-Windows frame in white
I need to dismantle the Stern
I first try différent shades of yellow to replace the gold.
I tried the historic shade called Yellow of Naples but I find it very ugly like almost "toy-ish"
Ok I am reverting back to gold but before I need to use my drill to pierce some détails of the balcony
I am also planning to add more détails, some columns are missing on the sides of the Stern, I will glue two wires and paint them in gold.
I will have after to glue them at the right places.
And now for the fun I have some gold leaves left from a funny baking session! I will apply them on the Coat of arms of the balcony.
This is my technique to make the gold paint less gold compares to a "real" gold lol
And the final result!
I think I need to paint the bottom line in Black instead of blue and gold
I have been using old telephone cable and pins to crafted the mettallic parts attached to the deadeyes
I just need to paint them black
You could use some wash to tone down color.
Hello everyone!
I've been working on the chain links, and boy, is it time-consuming!
Yesterday, I asked myself the question you've probably all asked yourselves: why do we enjoy suffering so much?! That's what came to mind while repainting the deck without removing anything (everything is glued on, and the risk of breakage was too great)... and without any smudges!
I chose a lighter wood than before for a slightly aged, sun-kissed, and realistic effect.
I finished my sterncastle after days of research online. I decided to paint my RL as it might have been in 1782; mostly yellow and black, with the exception, due to its name, of a blue stripe.
And finally, the first assembly of shrouds and deadeyes with my homemade chain links, plus a small triangular support for the mainsail handle.
What do you think? I made sure to put the deadeyes of the ropes connecting the mast a little higher than those of the shrouds, I don't know if I did it right.
