- Dec 1, 2016
Kit builders would have little to no use for a thickness sander planking material is always provided in the kit. But kits often provide just one size plank width for hull planking which to do a proper planking on a hull different widths of planking are needed for shaping planks, a garboard and bottom planks are wider that top planks. So in the case of kit bashing or scratch building a thickness sander is an essential tool. I have a big double drum thickness sander that 2 men could not pick up, i do not have a small hobby size sander so i cannot comment on any of the machines. This is just what is available plus the fact you can make a thickness sander yourself. There are also mid-size machines but unless you're into mass production of milling wood or general woodworking they are not needed for building model ships
what are your comments
www.microscopicmodelshop.com
Byrnes Model Machines - Thickness Sander
Byrnes Model Machines produces precision-engineered miniature Table Saws and Thickness Sanders for Ship Modelers, Dollhouse Makers and Model Railroad Builders; every machine has an accuracy measured in thousandths of an inch.
byrnesmodelmachines.com
Luthiers Friend: small precision model thickness sander
Thickness and pattern sander which fits on a drill press and is designed to meet the needs of musical instrument makers and serious modelers.
www.luthiersfriend.com
MicroLux® Drum Thickness Sander - www.microscopicmodelshop.com
Drum Thickness Sander Turns Your Shop into a Portable Lumber Mill Sands wood up to ½ inch thick and 5 inches wide 1/3 hp with drum speed at 5800 rpm with power and precision Works with sheets or strips of wood A Micro-Mark Exclusive Reduces hardwood down to 1/64 of an inch Sands wood up […]
