PLANS
Dave Stevens (Lumberyard)
Sponsor: dlumberyard
Sponsor
Every once in a while, there will be a post where do i get ships plans? good question but to general to answer, Ship plans come in a variety of forms like original shipyard drawings, modeling plans, plank on frame plans, plank on bulkhead plans, plans from kits and plans out of books. Here is a small sample of where to find plans, museums all over the world will have a collection of plans as well as historical societies and private collections.
sometimes ships are built "by the numbers" yes math is a big part of building ships.
the numbers are used to create patterns for the carpenters out in the yard, the guy in the middle holding the papers might be calling out numbers like bingo or the master shipwright checking the work being done.
Then you have plans such as this one, there is nothing to tell you what the stern looked like, what the figurehead was, nothing on the deck layout, no construction detail as to framing or timber sizes the plan is just the shape of the hull. To build a model from such plans you need to use other sources such as the "establishments" which is a document giving general timber sizes but not things like deck layout.
Before you can develop a set of working modeling plans a quick reference to the terms used
Length overall (loa): It is the distance measured parallel to the summer load waterline between the extreme points at the forward and the aft. The extreme point at the forward can be taken on the bulbous bow.
Length on the waterline (lwl): It is the distance measured between the intersections points of the bow and the after end with the summer load waterline. In case it is not mentioned, the length of the summer load waterline is taken into consideration as the length of the waterline.
Midship or amid ship : The midpoint between the aft and the forward perpendicular is known as midship or amid ship. The section passing through this point and which is normal to the waterplane is called midship section. The term ‘beam’ is quoted at amid ship. The breath extreme is measured at amid ship. It is also known as moulded breadth line.
Depth: The depth of the ship varies along the length. But the depth of the ship is taken as the distance between the undersides of the deck amid ship to the bottom of the keel. You might not get an exact value of depth as the hull is symmetrical and the depth varies thorough out the ship. For example, the depth is greater at stern than at midship.
Width or beam or extreme breadth: The width of the ship is also known as the extreme breadth. It is generally measured at the amid ship. It is the greatest distance between the two sides of the ship at the greatest width.
Sheer: It is measured as the rise of the deck towards the stem or stern. It is the height of the deck at the side above the deck at sides amidships.
Camber or round of beam: It can be defined as the side of the deck going from side to the centre of the ship.
Rise of floor or dead rise: At the amidships region, the bottom of the ship is extended out to intersect the moulded breadth line. The rise or the height of this intersection above the keel is known as rise of floor or dead rise.
Tumble home:
If the sides of the ship at the amidships is not vertical and if the upper deck beam is less than the waterline, it is said to have tumble home.
Draught: It is the distance between the keel and the waterline at any point along the length of the ship. Moulded draught is measured from the inside of the keel plating.
Trim: The difference between the draughts at forward and aft is known as the trim. Trim is mentioned as by the bow or by the stern depending upon which one is greater.
Freeboard: It is essential in determining the stability of the ship. It is the difference between the depth at side and the draught, i.e. it is the height of the deck above the waterline. Freeboard is generally less at amidships than at bow and stern.
This is all great info for a new learner being able to understand all these naval terms you may hear, but know exactly what is being talked about.
the Dictionary of American Naval Fighting Ships which describes Gracie S. as "length 83' 0"
when you look at the hull line drawing it says 95 feet 6 inches. Who is wrong? actually both dimensions are correct because it depends on who is taking the measurements and how ships are recorded and what exactly is being measured.
so what is going on here?
Length overall (loa): and Length on the waterline (lwl):
The 95ft 6 in is the LOA measurement and the red line is the LWL
Dictionary of American Naval Fighting Ships list the length of Naval ships at the LWL Admiralty drawings may record the length on deck or between perpendiculars. Then even between perpendiculars breaks down into overall and from the back of the stem to the front of the stern post. Then we have the add measurements which calculates the cargo capacity and cargo weight a ship can carry.
For model building the add measurements are not needed unless you love math and are into RC naval combat and you need to know how much weight you model can carry.
this is shown on the bodyplan
in the case of the GRACIE the draftsman noted lines drawn to the inside of the planking.
Some plans do not indicate what the breadth measurement is. But for model building it may not matter because at 1:48 scale the planking is about 1/32 thick so overall it is a matter of + or - 1/16 smaller scale the difference is minimal.
Length of the keel or touch: applies to English ships in the second half of the 17thC. - The length of the keel that is on the baseline of the draught. It is shorter than the length of deck from the rabbet of the stem to the rabbet of the sternpost of the main deck.
Breadth of record: on 18thC. RN draughts is the greatest width at the deadflat and also includes the thickness of the bottom planking. The actual Body Plan is to the inside of the planking so the value does not apply there.. For a ship as actually built the value also does not apply. The level of the greatest breadth is also the location of the wale. The wale was usually twice the thickness of the bottom planking - or more.
In the 18thC. Round up or To round how much higher is the crown of the midship beam than it is at the side. This value decreases going fore and aft. The ends of the beams are chopped off. They are not squeezed in.
Camber is the longitudinal curve from stempost to sternpost that describes the arc of the crowns of all of beams. Water runs to the middle from both ends..
Is it just me, or does anybody else notice that the first question every kit builder who has "gone over to the dark side" and is looking to build a model from scratch always asks is, "Where do you find plans?"
rather than just a posting where to find plans let's take a close look at a collection of plans. Th8s is a catalog dating back 30 or 40 years ago from the National Maritime Museum UK
click on the image for a larger readable view
the above list is the Admiralty collection and are the original drawings which means first off you have to understand what the plans are and how to convert them to modeling plans be it plank on bulkhead. plank on frame or a lift hull.
Bob brought up a good point what if the GRACIE S is too much for a beginner or what if a builder wanted to do a different vessel?
ok then here is a PDF file of every vessel and every drawing in the Historic American Merchant Marine Survey
to provide work for unemployed skilled or "white collar" workers. These projects were intended to provide work which was both useful and appropriate to the skills and experience of workers who were not suited for more traditional work programs involving manual or outdoor labor. The specific goal of HAMMS was to undertake a national survey of watercraft, in order to document the design and technical evolution of vessel types significant in America's commercial maritime history. This was to be accomplished by making measured drawings of existing vessels, ship models, and builders' half models; by making a photographic record of significant vessels; and by compiling written data about vessels.
The HAMMS program was in existence from January 1, 1936 to October 15, 1937. The Smithsonian Institution served as the official sponsor of the Survey and received all the documentation produced, thus augmenting its already significant National Watercraft Collection. Unlike other WPA projects, HAMMS was administered directly from Washington by its Director, Eric J. Steinlein, who coordinated the survey work of six regional directors. Despite its national mandate, the Survey actually was limited to the eastern seaboard, the Great Lakes, and California. Furthermore, the types of craft surveyed and the level of documentation varied considerably within the six regions. During the course of its existence, the HAMMS program conducted over 166 surveys and produced over 400 sheets of line drawings of ship's hulls, rigging, and details.
There are modeling plans available which are drawn as plank on frame but can be converted to plank on bulkhead or lift construction
I recently found out that the Wisconsin Maritime Museum has a copy of the HAMMS Great Lakes Vessel volume and today a took a trip down to look it over. Rodger - I am very glad I did not take a trip up to UW-Superior to look at their copy! I was actually very surprised of the overall contents, for some reason I had thought this would be a magical collection of information. My main reason for taking a look was to see the included information on Mackinaw boats. There are 10 sheets of plans associated with Mackinaw boats, however the plans are connected to 4 different boats and there is no complete set of information for any of those. What is clear is hull shape and construction techniques varied - hence there is no realistic way to use the 10 plans together.
With that said, I did notice a couple of examples of more complete sets of information: City of Pekin, a steam screw canal boat; a steam screw floating post office used by the U.S. Post Office (very cool, but looks like a hard modeling project - at least for me); a small inland Bateau; a lumber steam screw called Sidney O. Neff; and a few references of ships connected to my home of Green Bay.
But all in all, I would not pay money for this collection.
The term Mackinaw Boat indeed seems to apply to a variety of different small craft used on the Great Lakes. Chapelle discusses them along with sample drawings in his American Small Sailing Craft book. One of the more well documented variants goes by the name of “Collingwood Skiff.” Check out back issues in WoodenBoat magazine. They have had a number of articles.
Roger
