Bateau de Lanvéoc in 1:32 from Ancre Plans by JacquesCousteau
I'm partway through this build, so I figured I may as well start a build log, giving a quick run-down of the journey so far. I'm building it pretty slowly--I started in February and am still fairing the hull--so don't expect a quick stream of posts! I have a full build log on another forum, so this first post will just be a summary.
As a modeler, I'm most interested in small workboats. The varieties of local designs are fascinating, and researching and modeling them is a fun way to think about how people around the world adapted to big picture changes like globalization and economic development. I'm especially interested in Latin American vessels, but not exclusively. I've also always been drawn toward the fully framed modeling style, as I like the idea of working out every part of how a boat works.
I've been modeling for a couple years, and for my first full-hull POF model, I decided to build from an Ancre monograph, as I didn't want to have to loft my own frames. I initially considered the Gozzo Santa Caterina, but decided against it because of a few issues others noted with the planset, and because it would be miniscule and very challenging in my preferred 1:32 scale. So, I decided to go with Jean Boudriot's reconstruction of the Bateau de Lanvéoc. It's a very simple, single-masted open vessel, and rescaled to 1:32, it's a manageable size--the hull is about 15 in / 38 cm long. It has very full hull lines, and I find it an intriguing if very unglamorous vessel.
To briefly summarize, as the monograph shows, by the 1600s, the French Atlantic coast developed a number of similar vessel types characterized by one or two square-rigged masts. The Bateau de Lanvéoc was a distinct type used in the 18th century into the early 1800s as a ferry and coastal cargo hauler in the area around the important military port of Brest. Pierre Ozanne made a number of drawings of the vessel, and François-Edmond Pâris recorded a hull plan from 1830. The Bateau differed from other vessels in the region, such as the sharper-lined, lug-rigged Plougastel Boat used for fishing, in having a single square sail and a small jib, a seemingly outdated rig by the period that nevertheless persisted in use. After 1830, the vessel appears to have fallen out of use, increasingly replaced by gaff-rigged and eventually powered vessels. I found that several paintings of Brest harbor from the late 1700s and early 1800s seem to show Bateaus like those in the monograph.
I decided to make the model in alder. So far, I've found it to be a very nice wood to work. It's not as hard as cherry, but sands much smoother than basswood, and I like the color. I ordered sheets of alder in the required thicknesses from Ocooch Hardwoods, and I was pleased with the quality.
There are plenty of build logs that give a step-by-step look at POF construction. Here, I'll limit myself to a few general comments and notes about the monograph. With a few exceptions I'll discuss below, I've found this to be a fairly straightforward process, but the build definitely requires a lot of care and emphasis on detail. It's been a very rewarding experience, if a very slow one.
At the moment, the framing is complete. I added a lot of scrap support pieces, rather haphazardly, to secure the frames for fairing. I decided to fair the exterior first, and will add the internal parts after planking the hull. I'm still deciding whether to leave the model partly unplanked to expose the framing, or to just plank everything, as it's an open boat and the framing will be visible on the inside. I'm doing a little fairing here and there, rather than trying to fair everything at once.
The round stern, especially, is extremely hard to fair, and I keep snapping battens trying to check. I will ultimately have to do some substantial pre-bending to fit the planks around it. That said, the plans seem to show a very rounded stern, so I think that's how it should be.
I used a fretsaw to cut out all the parts. In the future, it would be a lot faster to use a powered scrollsaw, although I need to practice first to avoid wasting good wood. I also probably cut the frame parts a little too wide of the lines. Sanding by hand to get close took absolutely forever, so I bought a cheap dremel-type tool. It was useful, but sanding still took a very long time.
Another challenge that I had was simply setting up the building jig, which I made mostly of mdf. It was surprisingly hard to find bolts long enough to raise the top part of the jig high enough. After fruitlessly trying in several hardware stores, I had to just buy a long threaded rod, saw it to size, and file the sawn tips so I could fit the nuts onto it. This added a lot of time to the build.
Finally, I made things more difficult for myself by buying the monograph in French instead of a language I can speak. Dumb mistake, I know. It was substantially cheaper and faster via ebay rather than ordering in English or Spanish from Ancre directly, but google-translating the text a paragraph at a time has been complicated. Google Translate and Deepl are both not particularly good at dealing with maritime jargon. In the future, if at all possible I'll stick with languages I can read.
There are also a few issues I should bring up about the plan set. In general, I'm happy with it, and wouldn't have been able to reach the point I have without the plans. But, I want to bring up some things I noticed, to help any future builders.
First, a minor issue: the plan set does not include limber holes on the frames, or any sort of pump. Given that it's an open vessel, I suppose bailing would work (although it would be hard with a full cargo load or lots of passengers), but I feel like you would still want limber holes to better collect water.
Second, the top-down plan view is slightly narrower (about 2-3mm) than the tops of the frame drawings. At first I thought the top-down view might be at wale height rather than the cap rail, but it doesn't align that way at the bow and stern. Ultimately I resolved this by slightly widening the notches in the framing jig, but trying to figure it out added a few perplexing days to the build.
Third, some of the frames are supposed to extend beyond the rail to serve as tie-off points. Not all of the frame drawings include this extra length, though, and while I left my frames a little extra long, some won't be quite long enough. Further in the build I'll have to decide whether to live with shorter ones than shown in the plans, or to do repairs to properly extend them (the joints would be covered by planking).
Fourth, and most important: the plan set makes some baffling choices about the cant frames at bow and stern. This has been the single biggest problem I've had with this monograph. At the bow, the frame drawings for cant frames A and B simply don't bother showing the bottom ends of the cant frames--they end in an undefined way. These frames need to join against the stempost, but the details of how they should join are completely left out of drawings.
To resolve this, I did a lot of trial-and-error carving, needed to redo a frame, and ended up with rather mediocre joints that, thankfully, will be covered by the foredeck and hull planking.
The aft cant frames, D and C, are equally confusing, but in a different way. The drawings show them as ending on the keel.
However, they actually join with the deadwood. Trying to fit them properly against the deadwood, at the proper angle and height, was also a long process of trial-and-error. I ended up having to cut shallow notches into the deadwood, as otherwise there was nothing to hold the cant frames in the right spot and, especially given the complex angles, they tended to skate all over the surface of the deadwood when I tried to position them. I also had to cut the bottoms back a good bit, as otherwise the frames stuck out way too far to get a fair curve. Due to this all being trial-and-error, the notches ended up being a bit oversized--thankfully they will be covered by planking.
Even now, I'm not 100% sure that they're properly positioned. While I received some suggestions to place them with the aid of battens, the pronounced curve at the stern would require that the battens be pre-bent to the proper curve, which would add a lot of complexity to an already complex undertaking.
The issues with the cant frames are, so far, the biggest problem that I've had with this monograph. From what I can tell, cant frames are challenging to figure out in the best of circumstances, and I would expect a monograph to be a little clearer about them--I can see the aft cant frame drawings being a simple mistake, but the fore cant frame drawings simply seem unfinished.
Despite these issues, I'm enjoying the build. I'm getting close to finishing fairing, and its a joy to see the curves of the hull really emerge. I'm looking forward to getting to planking, which is actually one of my favorite parts of modeling, and I'm curious to see how the alder is to bend. I'm learning a lot with this build, and it's been worth it to struggle through the challenges.
I have not gotten up the courage to attempt such a delicate project - looking forward to how this turns out!
Thanks! Your Santos Dumont and Harbor Dredger builds certainly looked delicate to me. So far the fragility hasn't been much of an issue. We'll see how it is once I start planking, though. It's really that getting everything properly lined up requires a lot of attention to detail, a lot of test-fitting, and a lot of minute adjustments. It's been informative to see how having the joint between the keel and the frames off by a hair's breadth can throw the hull lines out of alignment. In future POF builds, I'd like to try to use battens to check as I go, but it seems like you'd need to at least roughly fair the frames to successfully do that. Definitely a challenge!
Actually the most fragile model I've made is the Emma C. Berry kit from Model Expo. The un-sistered basswood frames are not fun to work with! Each has a left and a right side, so there are grain issues all over the place.
Sounds good. I didn't do a build log, but I do have pictures from along the way and wrote an article about it that was in the Nautical Research Journal. So when you get to it, and if you have questions let me know as I can point out what issues I had dealt with / overcome to finish the model. It is nice once completed and worth the time spent!
Thanks, definitely!
Hi, I find your build a must do thing for myself. In my eyes you have a excellent little ship in your build. Can you tell me where I might be able to pick up a book for myself please? You have a very good detailed log of your build. Keep at it and please post up dates on your build please. Thank you and take care.
Thanks! The monograph is available through Ancre. You can also sometimes find it on ebay, possibly for cheaper with shipping factored in, but it probably won't be the english translation (which Ancre sells).
Your building jig solution looks fine. If you ever need to buy long bolts McFeely has quite a range. One example...
After a long break while traveling, I got back to the build for a bit. I've finished fairing the hull. I ended up needing to build up a few frames by gluing layers of thin shavings of alder, as can be seen below. Once the excess is trimmed off, the result is not very noticeable.
I then began marking out the wales by securing a thread with small dabs of white glue. The run looked good in the photos below, but I then realized they were placed a little low, so I had to raise them a bit.
Once I raised the wales, the next step is to mark out the sheer line. Here I've run into a challenge: follow the monograph drawings, or follow the original plans by Admiral François-Edmond Pâris? The monograph shows a nearly flat sheer with just a bit of rise aft:
While the Pâris plans show rather more sheer. It's still not much, but it is notably different (especially comparing the section views):
So, what to do? I think the increased sheer of the Pâris plans is a bit more pleasing to the eye, but I am concerned that following it might throw off measurements for other things and would probably require resetting the run of the wales, again. Images from Ozanne included in the monograph show some bateaus with rather flat sheers and some a bit more pronounced, so I think there's support for both ways of doing it.
In the photo below, I've marked the sheer with black thread (unfortunately a bit hard to see) following the monograph plans:
And below, with the sheer dropped a bit amidships to create more of a curve:
It does look to me like I may need to adjust the run of the wales a bit if I go with the greater sheer curve.
Between travel, work, and focusing on other builds for a while, it's been a long while since I made progress on the Bateau. The next step is planking. I decided to plank the wales first, then up to the sheer strake, in order to help strengthen the framework before I get to the more complex curves of the lower hull.
My planking method is the same I have used since learning on the NRG Half-Hull kit. With the plank locations marked out, I put Tamiya yellow masking tape over the frames. It's thin enough that the markings on the frames can be traced.
I should note that, according to the drawings, the wales should be made of two thick strakes running continuously from stem to stern. I don't want to try to bend thicker wood, so I'll make my wales in two layers. The inner layer will also be made of several planks per strake, as shorter planks are more manageable. None of this will be visible once the outer layer is on.
After marking the plank shape, I move the tape to a sheet of planking material--in this case, 3/64-inch thick alder--and use a French curve to connect the markings in a smooth curve.
I then cut out the plank, cutting slightly oversized.
I sanded the edges a bit to get it closer to the final shape, but I held off on final shaping yet--given the tight curve, it's tricky to hold the plank in place to check fit. So, I then soaked the plank, heated it, and clamped it to dry in place.
This is my first time planking with alder. As can be seen, the alder curved beautifully.
I then sanded it to its final shape. Now that it's curved, it was much easier to check its fit. I then glued and clamped it into place.
As the model is of an open boat, I made sure to clean up any excess glue with a damp brush and a knife--there's still a little to clean, below.
And with that, about 11 months after I first made sawdust on this build, the first plank is on! One down, many, many more to go.
I would need this delicate of a frame in a jig, else it would be matchsticks by now!
Great work!
Thanks! I assembled it in a jig, otherwise it would have been far more challenging. The frames themselves are a bit over 1/8-inch thick, so reasonably sturdy, and the improvised scaffolding around the top has held up surprisingly well, but they had a tendency to want to flex when I was fairing the turn of the bilge.
It's taken a while, but I finally got the wales (or at least their first layer) on.
The wales ended up ever so slightly wider than given in the monograph, probably due to changes introduced during lining out and/or the thickness of the pencil lead markings. This is a generic type rather than a specific vessel, so I'm fine with it. In my efforts to slightly increase the sheer to better match the Pâris plan, the wales also rise a bit more at the stern than in the monograph.
Overall, I'm pleased with how this is turning out. I'm hoping to be able to remove the scaffolding soon, as it gets in the way of clamping.
Planking above the wales took quite a while. I found it really tricky to get the planks properly shaped, and had to redo a few. The planks are a bit longer and wider than other planks I've done.
Finally, I had the planks on.
As can be seen, some of the scaffolding had to be removed while gluing, to make room for clamping. I went ahead and removed the rest in order to have full access to the hull interior. The model is pretty sturdy at this point.
Next up will be to fair the interior.
