Glue
I'm not sure about the chemical additive though.
From the Franklin MSDS for their Hide Glue:
ammonium thiocyanate 1762-95-4 1 - 5
cyanoguanidine 461-58-5 1 - 5
I do not know anything about either compound. They never came up in pharmacology and toxicology was not a course back when.
If were me, I would switch to Old Brown.
I know that Franklin will produce a strong bond. I had a situation with a hide glue bond that was supposed to be reversed. I used too much. I clamped too tightly.
I know that hot ethanol will kill hide glue dead. But the ethanol spread to PVA bonds that were to be kept and reversed them too. I think that you can be confident in your Franklin bonds. I also used it to glue felt to the bottom of a drawer (Grestner chest kit) and was not happy with the lack of initial grip.
Old Brown is supposed to have that.
Was just mentioning an alternative choice. Old brown looks great too. I'm sold on hide glue; it is a charm to use. Please note that it is not fully transparent but rather have a brown coloration. For some application that may be a deterrent... not for me so far though.
The 60g Amazon hide glue flakes for violin - seems to be pretty much the same as Old Brown. It is not instant or 15 min to warm up like Old Brown. Keep the flakes in a sealed Mason jar and they will out last you. They just need about 12 hrs for hydration. I bet that if the liquid form is in a sealed container and put in a freezer, it will last a long time. It is just a matter of the time to thaw. Hide glue is a protein. Too much heat and it will do what egg whites do when cooked. For hide glue the absolute max seems to be 150-160 degrees F.
Lee Valley has a model side hot pot. It is a water bath for its glue pot and a preset temp for the hot plate. It is not described in any instructions, but I have a feeling that any leftover liquid glue can be stored in a closed container (pt. Chinese takeout liquid container?) in a freezer for a long time instead of mixing fresh everyday.
It is a wider variety of glue behaviors, with an additional iniital outlay for the pot. If the freezer thing works, it is about as convenient as pre-mixed liquid without the short shelf-life factor.
