Dear shipmates,
I hope you had a lovely weekend with your loved ones. Let's continue. I had to think about how to glue and adjust the planks for the inner area of the hold. I decided to take baking paper into account, as I love it so much. I took several pieces of wood (FM), as they were supposed to simulate the curvature of the planks, and two rubber bands. Then I formed a surface, placed the baking paper on top and secured it with two rubber bands. Then I moved on to parts D1 and D2. These are the planks for the lower rear hold area. Glue them together. I adjusted both plank parts and checked if and where they didn't fit.
Then I took capillary superglue, which is very, very thin, and glued the two parts together. The advantage of capillary glue is that it is easy to apply and spreads very well. Unfortunately, you have to be careful with the dosage, as you can quickly end up with more glue on the parts than you would like. Another advantage is that it dries slowly. This allowed me to adjust the two parts and attach them to the Fm parts with the rubber bands. The baking paper ensured that I could easily remove the planks after drying. This was very important to me because the planks are so incredibly thin and, as I said, can break easily!
In this picture, you can see how straight the planks are. I have placed them upright so that you can see that they are really straight and do not yet have any curvature.
View attachment 560778View attachment 560779
And this is what the planks look like at the auxiliary points (FM). I hope that once the planks are dry, I will have managed to get the curvature right.
And surprise, surprise, I was delighted. My plan worked. I managed to get the curve right!
View attachment 560781View attachment 560782
And this is what it looks like after the initial sanding and adjustments, when the planks are inserted.
This was a little update, and I hope you like it!
View attachment 560783View attachment 560784
View attachment 560785View attachment 560786
