It reciprocates in the out but very fast.looks like a nice tool, i assume it vibrates, that would be more controllable in tight places.
i have an old oral b electric tooth brush i converted to a mini sander but its sort of an orbital rather than vibrates.
these small sanders do come in very handy.
How does it work ? does it have any power ?On a similar vein, I saw and have purchased the following micro drill ideal for tight spots and repetitive drilling for tree nails etc.
Bought one-off Fleabay that has a transformer for plug in power. Works great so far, but I don’t use it a lot, so…I've been using the 3-speed, DSPAIE ("Illusive Shadows") reciprocating sander for about a year and it's ideal for tight spots that otherwise might be very time-consuming to access. For 3D resin printing it works great for removing layer lines when the broad square head is attached with the 3M 180 grit adhesive-backed sandpaper it used. The rounded head works well to smooth out tight corners too.
The unit charges in <30 minutes and lasts up to 45 minutes. It includes a pressure-activated stall feature if it's pressed too hard against the surface. I've used it on hardwood bases to smooth out routing imperfections as well.
Full Disclosure: My first unit died after a month, but had worked so well, I immediately bought another, which has worked fine.
I have one of these and find it very usefull also find this very small hand held velcro block very useful
URAQT 75-sheet Sandpaper Set, 120-5000 Grit, Wet&Dry, with Sanding Block, for Woodworking, Metal & Plastic, Paper Backed, Cloth Backing, Silicon Carbide Material : Amazon.co.uk: DIY & Tools
URAQT 75-sheet Sandpaper Set, 120-5000 Grit, Wet&Dry, with Sanding Block, for Woodworking, Metal & Plastic, Paper Backed, Cloth Backing, Silicon Carbide Material : Amazon.co.uk: DIY & Toolswww.amazon.co.uk
The product I mentioned is cordless and uses a USB cable to rapidly charge.Bought one-off Fleabay that has a transformer for plug in power. Works great so far, but I don’t use it a lot, so…
Thanks I need a small light drill instead of using the DremelTony, please find a copy of the product specifications…..I hope this helps with any questions. I have yet to use the tool in anger!
What I’d like to see is someone manufacture a right hand drill for a manual pin vice hand drill. Dremel sell a right hand drill, but it’s way to large to get into really tight spaces.
