It reciprocates in the out but very fast.looks like a nice tool, i assume it vibrates, that would be more controllable in tight places.
i have an old oral b electric tooth brush i converted to a mini sander but its sort of an orbital rather than vibrates.
these small sanders do come in very handy.
How does it work ? does it have any power ?On a similar vein, I saw and have purchased the following micro drill ideal for tight spots and repetitive drilling for tree nails etc.
Bought one-off Fleabay that has a transformer for plug in power. Works great so far, but I don’t use it a lot, so…I've been using the 3-speed, DSPAIE ("Illusive Shadows") reciprocating sander for about a year and it's ideal for tight spots that otherwise might be very time-consuming to access. For 3D resin printing it works great for removing layer lines when the broad square head is attached with the 3M 180 grit adhesive-backed sandpaper it used. The rounded head works well to smooth out tight corners too.
The unit charges in <30 minutes and lasts up to 45 minutes. It includes a pressure-activated stall feature if it's pressed too hard against the surface. I've used it on hardwood bases to smooth out routing imperfections as well.
Full Disclosure: My first unit died after a month, but had worked so well, I immediately bought another, which has worked fine.
I have one of these and find it very useful
The product I mentioned is cordless and uses a USB cable to rapidly charge.Bought one-off Fleabay that has a transformer for plug in power. Works great so far, but I don’t use it a lot, so…
Thanks I need a small light drill instead of using the DremelTony, please find a copy of the product specifications…..I hope this helps with any questions. I have yet to use the tool in anger!
What I’d like to see is someone manufacture a right hand drill for a manual pin vice hand drill. Dremel sell a right hand drill, but it’s way to large to get into really tight spaces.
It is good to see you have purchased the regulation green cutting mat.I picked this up recently. Dspiae sander. Great for tight places. Comes with extra pads for all the different head shapes. You won’t be sanding hulls with it but it does take down hardwood for fine detail sanding. Oh yea, new cutting mats to replace the 20 year old ones I had !!
In a similar vein, I have used this "nail drill" extensively for sanding, drilling in soft wood and carving. It certainly does not have the torque that a Dremel has but is great for minor jobs. You can get them powered by a USB "brick" or rechargeable. The real advantage is its small size. it fits easily into your hand and is not bulky like a Dremel. For a guy like me who is naturally clumsy it is a big advantage. It does not take Dremel size shafts. It take 3/32" shafts. That being said I have found arrowmax drill bits on Amazon and carving burrs on model expo that work great.On a similar vein, I saw and have purchased the following micro drill ideal for tight spots and repetitive drilling for tree nails etc.
