If putting the decals on the aircraft is one of the highlights for me, then masking canopies is the nadir. I have been finding little excuses not to do it; too tired, too busy… But even a master procrastinator such as myself can’t put it off forever.
First, sharpen your saw - or in this case fit a brand-new blade.
And the old blade is safely put away.
I always use Tamiya masking tape. It’s more expensive than some of the alternatives, but it is the best, in my opinion?. (Other opinions are available. Terms and conditions apply.)
Once the tape is in position, I push it into the angle between frame and windscreen with a toothpick. Preferably a wooden one. This bamboo rubbish is splintery and hard enough to scratch the plastic. It was misleadingly advertised as wood, but at least I got my money back.
Then comes the drama. Running a knife around the edge of the frame. If your blade wanders you will make an irreparable mess of the glass!
The compound curves of the movable canopy aren’t as tricky as you might think. I simply work around the edges and then fill in with scraps.
Using masking tape on a deeply concave area such as an undercarriage bay is very difficult for me. Packaging foam is much easier and more secure.
And ditto for the mains.
With the masking done, I have given the Jaguar a nose job
