- Oct 10, 2023
I guess I'm late for the party. Most YQ Bluenose entries were made several years ago. I started my build November 17, 2025. I used Google Translate to covert the instructions to English. I also refer to Ron McCarthy's Building Plank on Frame Ship Models book for some of the nomenclature. I'm in the middle of finishing the keel and modifying the frame notches to fit the keel. The keel notch in the frame is 0.1670" and the keel width is 0.1850". I saw no mention of that problem in 'some' of the SOS input. I did see that there was a problem with the frame 'legs' fitting in the notches in the jig (slipway). I found one frame that would fit the notch and that frame was not perpendicular to the jig. Hmmm...
I read that the member that mentioned the problem of the frame legs fitting the jig notch widen the jig notch. I might be messing up, but I'm thinning the legs. The instructions indicate frame one and frame 49 are glued to the keel and attached to jig. Then the rest of the frames are installed. There is a photo in one of the Build Logs that someone thought, as I do, install the frames, THEN add the keel.
Reading ahead (!!) I looked at figure 7 when the keelson is installed. It appears that that the brass wire is installed in the keelson to frame. Looking at the photos in the instructions, that step isn't evident. Did any one do this? That is a lot of #74 holes to drill, especially after the frames are still in the jig.
I would really appreciate any comments.
Bob Walters
Portland, Oregon
Bob Walters
Portland, Oregon
