Hello and welcome — that’s an excellent question, and you’re definitely not alone. Most kit sanding blocks are only a starting point (if any), and many builders replace or supplement them fairly quickly. Below is a simple, effective sanding setup that works well for most model ship work, IMHO
Sanding blocks (flat work). For straight runs like bulkhead fairing, deck edges, and hull planking:
A hard sanding block (made of wood, acrylic, or cork) is essential; it keeps surfaces flat. You can easily make your own by gluing sandpaper to a small piece of wood or MDF. These work far better than soft kit blocks for shaping hulls.
Sanding sticks (general shaping). For edges, curves, and controlled material removal: Sanding sticks or nail files (the hobby type, not coarse drugstore ones) are very useful. Different shapes (flat, tapered, and rounded) help you reach tight areas. These are great for beveling bulkheads before planking.
Foam sanding pads (curves & finishing). For final smoothing and curved surfaces: Foam-backed sanding pads conform to gentle curves without digging in. Excellent for final hull smoothing after planking. Use light pressure, let the grit do the work.
Useful grit range (you don’t need everything). A small, sensible progression is:
- 120–150 grit → heavy shaping/fairing
- 220–240 grit → general smoothing (most-used)
- 320–400 grit → pre-finish smoothing
- 600+ grit → final finish (optional, before paint)
You’ll spend most of your time in the 220–320 range, IMHO
A key beginner tip: Use long strokes, especially on hulls, and avoid sanding in one small spot. Check symmetry often (by eye and by touch). Stop early and check; it’s much easier to remove more material than to put it back.
Here is my personal like tip: Wrapping sandpaper around a ruler, a dowel, a scrap strip of wood, a rubber shape … gives you custom tools for almost any shape.
Finally, don’t worry about having “the perfect tools” - technique matters far more than brand. With a few basic blocks, sticks, and the right grits, you’ll be well-equipped.
Sorry for the long writing, hope this will give a basic idea.
