HMS Enterprize 1774 Scale Scale 1/160 Midships Cross Section
Beautiful workmanship Günther!
When I purchased the 1:160 Enterprize stern section, I also got the CNC'd detail parts, which included the wall panels that are cut to actually resemble frame-&-panel construction. I was saddened to find out that Unicorn is not making a detail kit like that available for the mid section, so I'm hoping - when I eventually get to that model - to dust off my chip carving skills and cut those panels. The difficulty, of course, lies in the thickness (or should I say "thinness") of the panel. Hopefully there will be enough scrap wood to practice on first.
Hey shipmates,
Here's a little update from me. I've now started work on the interior of the decks. I've decided to cut out a door and window in section K1 R. to make it look a bit livelier below deck. I'm also not going to close all the gratings, but leave them half open to improve the appearance. My boat builder will of course inspect everything... Hopefully he'll say it's good... I hope you enjoy the photos...
View attachment 563169View attachment 563171
I installed the first frame for the gratings...
and here are the cut-out door and windows... so tiny...
View attachment 563173View attachment 563174
The master boat builder is Mr McRoudy's right-hand man ... he is very critical ...
And here you can see how beautifully curved the upper deck is. It looks really great and I'm delighted that it worked out ... Now it just needs to be sanded down and installed. I love sanding ... :eek:
Wonderful Gunther. Cheers Grant
That is SMALL. Great job, Günther.
Hey Peter,
You're right, it really is very small. It's really very challenging. But I'm full of enthusiasm and want to see it through to the end. I really hope that my hard work will be rewarded and that this little model will turn out beautifully. I'm always happy when you drop by. :D
Hey Russ,
Thank you for your kind words, I'm blushing. :eek: This model kit is a real challenge. The laser-cut parts turned out really well. I can understand your enthusiasm for recreating the parts. But I have to tell you, it won't be easy. We're talking about tiny parts here that could break just by removing them from the frame. Unfortunately, that happened to me quite a few times. But thankfully, I was able to repair many things without it being noticeable. When cutting out the panels and the doors and windows, it was really difficult not to cut over the lines, let alone tear the plate apart completely due to too much pressure. If you really want to carve it yourself, you're always working in a range of less than 1 mm. The thickness of the board is 0.05 cm. The laser cuts in the panels are in the 0.1 mm range. I tried carving it myself a little, but without a machine (CAD) and a milling cutter, I reached the limits of my craftsmanship. :DThumbsup
Hey Richard,
Thank you very much for stopping by, and I'm very pleased that you like it. How are things with you? Has your enterprise found its resting place yet? I would love to see a picture... :DThumbsup
I'm still waiting for parts for my thicknesser, so It will wait until I have the material for the remaining cannon carriages. Meanwhile I'm slowly working on the 1:96 scale interspersed with learning my latest Beethoven.
Hey Richard,
That sounds like a plan. I wish I could play the piano. I've always wanted to. But unfortunately, my circumstances meant that it wasn't possible. Now I have the time, but I'm afraid I'm too old to learn. What do you think as a piano player? :D
You could learn to play some favourite tunes, maybe even more, but it is much slower for adult learners. With adult learners a huge amount depends on having a tutor. The internet tutors, and youtube, rarely cover the importance of posture and the many other factors that are required for learners who have already developed muscles and ligaments. Poor advise will instil bad habits that will be almost impossible to correct and may even cause injury.
Hello Richard,
Thank you for your reply. So that means: just start playing, preferably with a teacher. I agree with you when you say that it's not possible without a really good piano teacher, as posture is extremely important. How often should one learn with a piano teacher each week? Of course, I would have to learn to read music and yes, I need a piano. The only downside is that it has to fit in the flat. Unfortunately, I don't know much about it and I don't know what the prices are like. I know there are pianos that are beyond my budget. What would you recommend?
Best regards,
Günther
Hello Richard,
Best regards,
Günther
Sure a piano is nice, a decent 88 key digital piano would be fine. It is a common problem in flats.
The main thing is a getting tutor. They will be able to assess you. I would generally say to avoid people who teach more than one instrument (unless it is organ), but also to avoid a teacher who doesn't have experience with adults. Children are easy to teach and very quick to learn because their brain is rapidly developing. The job for adults is to impose the piano on less flexible organ and musculature. This must be done slowly. A teacher that does not insist that adults much first approach the piano slowly is not experienced with adults. Music theory, should be taught early, and adults are usually better pupils than children for that one!
A piano is beautiful, of course, but a decent digital piano with 88 keys would be perfectly adequate. This is a common problem for people with a flat fundamental tone.
The most important thing is to find a piano teacher. They can assess your ability. In general, I would recommend avoiding teachers who teach more than one instrument (except the organ), as well as teachers with no experience of teaching adults. Children learn easily and quickly because their brains are developing rapidly. The task for adults is to adapt piano playing to their less flexible muscles and organs. This must be done slowly. A teacher who does not insist that adults approach piano playing slowly has no experience with adults. Music theory should be taught early on, and adults usually learn it better than children!
Hey Richard,
I appreciate that. Thank you very much for your reply... It's nice to exchange ideas like this...
Best regards,
Günther
What ho, shipmates :D
I've been trying to find time despite my busy schedule, as Christmas is just around the corner and my admiral needs all hands on deck. Nevertheless, I've managed to convince the admiral to let me work on the HMS Enterprize for at least a little while.
In the meantime, I have tried to connect the hold deck to the hull. To do this, I had to adjust the deck to the hull, of course. I found this to be not so easy. I also find it illogical that the deck is not lined, but instead glued directly to the ship's side. Later, however, you can glue the knees in place to make it more stable. However, I noticed that this doesn't really help, as I once applied too much pressure to the deck and it came loose in one place... It's a good thing that the deck doesn't have to bear any weight. Nevertheless, I think it looks really nice... As always, here are a few pictures of the progress and please excuse me for not making faster progress.Thumbsup
To glue in the Orlop deck, I first had to assemble the template from the parts (CM1-5 to CM3-5) so that I could position the Orlop deck ...
This is what it looks like when the panels are glued in place...
By the way, here are my two builders. Mr McRoudy, whom you already know, and my builder Mr White... The difference in size between the two is enormous. Mr McRoudy is 1:84 scale (2.1 cm high) and Mr White is 1.1 cm high.
And here are the pictures after removing the template. Result: It turned out really beautifully. Wonderfully curved...
View attachment 564499View attachment 564500
View attachment 564502 View attachment 564503
View attachment 564504 View attachment 564506View attachment 564505
View attachment 564507 View attachment 564508
View attachment 564509View attachment 564510
I do love your constructie site with all the ‘old-fashioned’ attributes to install the curved deck, Günther. With a beautiful outcome.
Gunther you are owning this! Cheers Grant
What a beautiful piece of craftsmanship!
You're a master artisan. :D
Hey Mellpapa,
Thank you very much for your kind words. Unfortunately, I am not a master, but rather a modest apprentice who still has a long way to go before becoming one. You, on the other hand, are a true master. I love your Silent Mary...:DThumbsup
