USS Constitution 1:70 Scratch
Wow Mustafa. So realistic. Throw a little rope on your channel and we wouldn’t be able to tell the difference from the real ship to your replica. Cheers Grant
I prepared the main stays. To make the mice, I first drilled a 1.5 mm hole through the center of a 5 mm diameter dowel, then turned the dowel on my lathe. After that, I threaded a 1.2 mm rope through the hole in the mouse and seized it using my seizing machine. Next, I attached the 5mm bulleyes I had made to the ends of the ropes and connected the lanyards to the bulleyes.
