Is the gar plank glued into the rabbit or just set into it? CA good for this? if so, what thickness?
PVA will loosen when exposed to water or alcohol. Once you have the damp plank in the position you want, clamp it into place and let it dry before you glue it.I have the gar planks on, but snapped the next plank right at the bow. The PVA holds until I soak the plank. What would a good glue be for this repair.
This is a new phone, the old one "sank". Still trying to figure out the photo side, not the same.
After soaking the planks, if the part attaching to the frames is wiped dry, can they be glued immediately after with the PVA glue with clamps?Glue the gar plank into the rabbit. I like using PVA glue such as tight bond and clamping it into place. Don't forget to bevel one edge of the length of the planks so they fit together more closely. Also glue the plank edges to the next plank not just glue the planks onto the bulkheads.
Rob
I would perhaps use a hair dryer or heat gun to dry out the planks if you were in a hurry. I don't know if you dry the surface would do the trick.After soaking the planks, if the part attaching to the frames is wiped dry, can they be glued immediately after with the PVA glue with clamps?
I have been waiting overnight before adding thr next plans and was wondering if that would speed up the process.
Well my buddy came over and wanted to see the Lobster Smack, so I got it and was bringing it to him, tripped on the stairs and dropped it to grab the handrail. That brokAfter soaking the planks, if the part attaching to the frames is wiped dry, can they be glued immediately after with the PVA glue with clamps?
I just left my Norwegian sailing pram the color it came in and I think it looks fine.Ok, while waiting for my new kit to arrive I thought I would get the sails ready. I have seen some stain their sails with tea. That seems problematic to me as tea is acidic and I don't know how long before it would be, or even if it would be a problem.
What do you do to stain your sails or do you just leave them white, or whatever color your sail cloth happens to be?
