Progress on Peapod
Bryn Mawr PA US
Making progress on the Midwest Maine Peapod. First time trying to "weather" the oars and the lobster traps (I made 2 because I may do a diorama with the traps laid out to sea). I also tried to weather the inner hull but did not want to distract from the planking. Next step is to build a stand, put string handles on the oars, and add the rub rails and rowlock blocks. Painting the buoys then I should be done. This is my 4th wooden ship build and I'm loving it.
I just noticed your support stand. Can you post information on this, it was a new one for me.
TIA Ignatius
TIA Ignatius
Allan - Here's a link to the boat stand I am using from Amazon.com. I've seen it available from many different distributors and at a lower price than $26. I find the cambered edges on the frame holding bars to be its best feature for boat model building. Funny...after this build I am going to upgrade to a stand with measurement markings to help be more accurate during construction. I hope you find it useful. /Ignatius
Sigvetan Stand for Model Boat kit Berth jig Stand Building aid Tool, for Most OF1/350-1/700 (Grey-3D Printed)​
Your peapod looks great! I built one in the past and it was a lot of fun. Nice job on the lobster traps! The lobsters are a cute add on. To weather the lobster traps you may want to add a bit of gray streaks. When I did mine I went more with a gray and bare wood, the salt water really beats these things up.
Welcome aboard from Connecticut!
Rob
Rob
Thanks Rob! Can I ask what paints and/or stains you used for your Maine Peapod? Im trying to stick with water-based stains for most of it, but I may need to use acrylic paints for the buoys. My spouse hates the smell of turpentine and my work space is in the attic above our bedroom.
THANK YOU!
THANK YOU
I used Tamyia acrylics white for the exterior and tan for the interior. After some sanding I do use a couple of coats of sanding sealer (others use shellack) before I apply the paint. I find acrylic paints tend to raise the grain and it looks fuzzy. The sanding sealer does have a smell. The Peapod was airbrushed, but I have hand painted with good results. When I stain I use minwax stains which do not have a strong odor.
The Maine Peapod is complete! Despite screwing up the hull planking (I planked bottom-up instead of top-down), I think it turned out well after faring and staining the hull. The one visible flaw in my build is the extra 1-2/8 inch of mahogany strip where the rub rails meet at the bow. I also should apply some graphite to weather the ropes. I may go back and fix them sometime down the road but I'm eager to move to my next build, a cheap wooden version of "La Real" a Spanish oared galley. The first pic is a silly diorama with mini-lobsters that I created for my friend, who I am trying to interest in starting a modeling club at our church by gifting my boat to him. I fabricated the stand out of balsa wood. I estimate this build took me between 90 and 100 hours of work -- not sure if that is good or bad for my 4th wooden boat build. Thanks to all of you who gave advice on weathering and your encouragement!
