- Sep 10, 2024
Having just built a full size 32" Viking shield, I can offer that the backside 'reinforcing' pieces are what hold the shield planks together and are fully necessary as it's all butt joints on the face.
As for different shield plank widths, I think there is no purposeful reason to make them the same, and saving extra work as a warrior or craftsman on an expendable piece of gear is a plus. Also, depending on your handle configuration, shield boss size and placement on the laid out planks, having same width planks may cause some small pieces to be impractically small, like at an edge or by the boss where the cut out is. I'd be wary of authoritative or definitive statements on Viking shields as these undoubtedly had an element of practical necessity in such a widespread culture, meaning the practices would vary with the wood, time and skill available.
Regarding model sized shield rims, I laboriously hand cut a thin wall copper pipe into slices to use as shield rims, then painted them, with a nice result. Although if i was going to do it again, i'd array my shields in a column, roll that tightly clamped stack/column in adhesive so all the edges get glue on them, then roll the stack in thick AL foil and let it dry. At that point, you just slice off each shield. if you wanted a specific color or patina, you would just treat the face of the foil before this process.
All that said, I love this particular ship and I can see you're doing it more than justice, bravo!
I would love to see some photos of your full scale shield!
