La Renommée 1744 Stern
Which Blender addons do you recommend for ship design?
Thanks!
Extra Curve objects is handy., but generaly speaking there's no addon for ship modeling. It just depends how well you know program and what you lack. When you get to that point you'll know what you need
1/48,1/72
This one is for my, but I plan to make others for some kind of simplified kit
Let me know the moment the kit is ready. My level of skill is full-bulkhead only which makes the CAF full-rib model kit unhelpful. I hope you could do the kit in 1:64 instead of 1:72 because of the higher level of detail possible without creating too huge of a model. TYVM
To be honest. I have to think it more through. At this moment I'm making it for myself, but I don't reject any options. At the beginning I wanted to make only a stern model, turned out I was capable of more. I still have Soleil Royal to finish and have little dilemma which direction to choose
@WojtasS, thanks for your post. you mentioned the following in your first post:
I had to really squise potential from Blender and made a loft of hull in one program without any other CAD software. It turns out with enough addons blender
has enough CAD-like functions to properly loft a hull.
Would it be possible to know which Blender's addons you find essential? a thousand thanks.
Someone has already asked a similar question. Not much has changed in the answer. You need to work with the programme and browse through guides to see which functions seem to make your work easier, but this is an individual matter.
Hello
Some couple of month passed since I last posted something. I've been busy with finishing rest of decorations of La Renommée.
Now I can finally show my results. Since this is a 3d-printable model it will take some time to test print and fit everything together.
The reason it took so much time is I needed also a compatible hull even for a stern section only. I made some prototypes for testing, but results weren't satisfying enough.
Now I have a dilema wether should I make another 3d-print stern model or should I complete at least hull. I miss working with wood, but on other side is bringing back to life
beatiful ships existing only on drawings.
Lofting a hull is not enough now I needed to finish it somehow. I didn't want to have entire hull 3d printed-too long printing time and I have only resin printer.
I managed to design something in between, hybrid of sort. Lower body benteeth 1st deck is laser cut plywood, upper is 3d print with all the fancy curves of ship already established
Other dilema I have if I decide to go with the hull. Should I make La Renommée or her sister ship La Comete:D
I'm not sure I missed something; La Comete? I thought her sister ship is La Sirenne. I want to build La Renommee, but I fear doing the carvings. However, I would proceed with a build if I could buy resin carvings at 1/48.
In my humble opinion, it doesn’t really matter whether it’s La Comete, La Renommee, or La Sirenne, because as you write:
“...but on the other hand, I’m bringing back to life
a beautiful vehicle that exists only in drawings.” "
What matters is that what you create makes sense and looks good. Personally, I’d go with finishing La Renommee... But maybe the necessary sculptures could be found somewhere, and I’m keeping my fingers crossed for that.
Best regards
Translated with DeepL.com (free version)
Hi. I might be wrong calling La Comete siter ship. Mr Boudriot in his book "The History Of The French Frigate 1650-1850" calls them very similar in compostion of design as the sculptures are work of C.P Caffieri. La Comete was build in Brest in 1752. Mr Boudriot also show design of other 8pdr frigates 1753 Licorne and
1755 Fleur de Lys
As for selling resin carving of Renown. La Renommee is my private project and I don't intend to sell them. However I plan to make other ships which will be for sale, but it requires more time and and feedback from community.
1755 Fleur de Lys
Thank you for answering, and so quickly too. I will try carving the decorations from wood.
Little update on La Renommee project.
This is one of the most important phases that shows in real life whether the computer project is consistent or whether there are some errors that are not visible at first glance.I managed to put the hull together, but unfortunately, a design error occurred that affected the stability of the structure. The base of the resin sides of hull is too thin, and there were a few minor mistakes.
This is what they look like after the corrections. The beams are finished; all I have left is to re-cut the decks that will hold the resin parts of hull
In the meantime, I've been working on another project that I have much higher hopes for. I think it will be a much more interesting model because there are no fully developed plans and I must use historical sources to complete equipment of this ship . The decorations are mostly finished, but I don't want to show anything until I'm happy with the result. For now I would like to show only the stern, maybe someone can guess what model it is :)
This is way above my grade, I don’t understand much of it but I’m finding it fascinating and the way that you’re explaining your ideas make for very interesting reading.
Thanks. You can write what you can't understand I will try to explain it more
This is a remarkable piece of work.
Thanks. Much appreciated, especially from the mouth of incredible craftsman. I'm experimatning with methods of creating a hull, it's easier to change something from scrach. I'll propably test it on Briliant and re-do Renommée
