Thanks, Allan, that would be great.If it works, go for it. Thanks for posting. FWIW I found breakage was a problem doing it this way years ago so went with the old tried and true method I first saw in Bernard Frolich's book, The Art of Ship Modeling. There is no breakage and it accurate in forming the ledges and battens even at the smallest scales we normally see. I'll try to make a sample and photograph the steps along the way and post in the Tricks of the Trade topic here at SoS.
on my part, or a misunderstanding of drawing.
Looking at the stern timbers resting on the wing transom (base plate) do your plans show any other views? The side stern timbers appear to the be the same height as the others, that does not match the contemporary drawing which shows the outer timbers about 37 inches shorter than those in the center. Also, I am pretty sure she was built similar to other ships of her time even as a merchant vessel, so the outer counter timbers would not be straight, but rather would be rounded to the planking is a smooth transition from the side of the hull all the way to the end as the stern. https://www.rmg.co.uk/collections/objects/rmgc-object-86456
Hi Allan yes as shown on this drawing>
Aut inveniam viam faciam (I shall either find a way or make one) is a good mind set for ship modelers at times. You have provided another solution that will hopefully help another member down the road.By Jove, it worked and just in time too.
Hi Allan, Absolutely, and I agree whole heartedly. Also, I managed the tightness of the string to leave no marks on the wood. I found out if I only passed the string over itself 3 times was enough to stop the string loosening.Aut inveniam viam faciam (I shall either find a way or make one) is a good mind set for ship modelers at times. You have provided another solution that will hopefully help another member down the road.
Drilled a hole that would centralize on the centres of the Dividing head
Machined an octagon to the correct size of the Pawl Pitt Octagon....
Then parted them, nearly, but leaving enough to use my jeweler's saw to cut through the remaining piece of wood, as that's when most mishaps happen, as the parting tool breaks through the wood.
Fit and glued the bushes into the Pawl Bitts
Thanks Mate, enjoying doing it too.Your build is looking very nice !
