Occre HMS Beagle 3
Hi all. Well I've made a start on my Occre Beagle. I've called this thread Beagle 3 because there are two others who have also started this kit recently.
The first thing I realised was that although I have countless tools collected over a lifetime, only a few of them would be useful for building this ship. So out came the debit card and shopping started (and as any tradesman knows, buying tools is actually an enjoyable experience :)). I think I have most of what I need now, but no doubt you helpful people will advise if I need anything else.
I realise there are a couple of important items not yet in the tool kit. A pin pusher and a plank bending tool. But I was going to ask advice on those as to the best type to get.
Anyway, below is my modelling tool kit so far.
Thanks for posting. When the second video came on I could not stop smiling!!! Using tick strips to measure the breadth of the planks is great to see. Minute mark 5.09 to 6.36 is so important to properly plank a hull if the planks are not spiled yet no kit ever shows this as far as I know. Except for a couple kit makers that offer spiled planks, this will be most helpful for folks working with strip material. THANKS AGAIN FOR POSITING.
Oddjob, I don't see any sanding blocks or sandpaper. Also, you need a set of micro drill bits and a pinvise. Instead of a plank bender, I use a soldering iron. It works extremely well except that it leaves scorch marks on the wood which is normally on inside of model and doesn't matter. I do use a pin pusher but only push them part way in so that they are easy to remove. Once you get to rigging, a helping hands tool becomes invaluable.
Oh the joys of buying tools!
Good luck and enjoy your Beagle kit.
Thanks for your reply. If you look at the first picture, at the very top that black thing is a sanding block (I have loads of sandpaper in my workshop). Just below that there is a set of rigging tools (blue handles) and to the right of those is a set of micro drill bits and a mini drill (although that is next to useless as it has no power, so it's being returned).
Not heard of a pin vice?
I have a friend who has completed the hull of this model. If you are in the South of England I could put you in contact with him. You can contact me by going to the website <modelshipwrights.org> and request to have your enquiry directed to the Chairman.
A pin vise is a small handheld manual drill for micro sized drill bits.
I am wrapping up building Beagle my second build.
Glue dispenser with the long plastic tips to control flow and get into tight spots using CA glue. I also use white glue.
Have you got round to explaining to your Admiral why you have spent more on tools than on the kit? Having said that it is definitely a good investment particularly if you plan further models. Looks to be a good start from the tools you have.
I would also suggest:
- Needle threaders which are useful when threading deadeyes and rigging blocks
- Japanese shears for making precise cuts on threads/rigging
- Mini mitre block for more precise cutting
- Light weight vice/helping hands to act as an extra pair of hands, particularly when tying rigging knots
- Assortment of small paint brushes
- Bit more expensive but a Dremel and assorted tools. Not immediately essential but I have found very useful on many jobs.
I haven't posted much about my build yet so this is a catch up of progress so far.
Firstly the easy bit of constructing the frame, well what should have been easy. I found that the pre-cut frame pieces were not marked so I had to use the deck section to get them all in the right position before gluing. It was only a short while after I found a schematic in the plans showing where all the pieces were. First muppet moment :rolleyes:
Then work started on planking the deck.
I cheated on this part by cutting the deck planking to shape using my bandsaw.
Then the fore and aft bulwarks and decks added.
Then I was waiting for glue to dry so I made a start on the small lifeboats?
I am not looking forward to planking these as they're so small :eek: Then onto the planking of the hull.
I didn't remember to take photos during the planking but here is the finished hull after first planking. I'm thinking the secondary planking will be easier as the 1/2mm thick boards will bend so much easier than the 2mm boards of the first planking. Also you'll notice that I've planked over the fore and aft gun ports as they were defunct, and I thought planking over would look better than fitting dummy doors to the ports.
And I've also made a couple of the deck parts (not sure what they're called).
And that's the build so far folks (constructive criticism always welcome). I might make a start on the secondary planking this afternoon :).
Looking very good so far. You copied me by framing out the dinghies early. You are correct, they are very hard to plank. I have done one of them so far.
Keep up the good work.
Good progress. Regarding the lifeboats I would suggest you cut the planking strips lengthways so they are half width. I did that on my Endurance build which made it much easier to plank.
Agree with Keith on the planking of the lifeboats. Easier to deal with and I think looks better.
