My 1/72 scale aircraft
Ki-44II Shoki update…
It’s definitely a tiny aircraft…basically the size of a WW1 aircraft.
I put the base coat of silver on, then finished painting the landing gear bays and the tail gear.
Up top I painted the black anti glare strip, the exhaust and did a little weathering on the cowling area to get an idea of what it is going to look like. Then the tail was painted red.
The motor isn’t as detailed as I would like, but once the prop goes on you won’t see much of it anyway.
Next I have to paint white bands on the wings and fuselage where the red circles go. Then I have to paint the rest of the black on top of the fuselage that overlaps the white some.
Then finally I have to paint the leading edge of the wings yellow, and also the guns.
After that it will be time for decals. My favorite part of the build because that’s when you see the final look, minus weathering.
See ya next time…
View attachment 579457View attachment 579458
See ya next time…
Looks great !
I decided to concentrate on finishing the fuselage and empannage and then do the wings.
So after decals, weathering and clear coat, I added the gun sight.
Then the canopy was painted and glued on.
A few pics of current progress…
Now to paint the white and yellow on the wings and add decals, weathering and clear coat…
See ya next time…
Painted the white bands on the wings…no fun!
Then I painted the yellow on the leading edges and then added the decals. Then some clear varnish and some weathering…
Next to a Bearcat for size reference…
Next will be landing gear and doors. Once on her feet, I will add the prop and antenna last. So probably another days work.
See ya then…
View attachment 579604View attachment 579605View attachment 579606View attachment 579607
See ya then…
Painting white is a pain ! Especially when you are brushing it on ! Yours turned out very nice !
When you get to the A-7D let me know, I worked that aircraft for over 3 years! Lots of memories and scratches from bumping heads into pylons.
Thanks Kurt, will do! That was an awesome aircraft, with a great record and longevity, that was finally replaced by the F-18.
And thanks for your info on the A-10 on ordinance locations. I have to go back to it eventually and relocate the ECM pod and sidewinders. Thanks for pointing out my error. ;)
F-104 Starfighter update…
Completed steps 5 and 6
View attachment 580476View attachment 580477View attachment 580478
Working on step 7 and preparing parts for the next 3 steps…
See ya next time…
Like all your other work, the "Manned Missile" is looking great !!!
It looks like you decided to not "open holes" noted in step 5. I'm assuming that is for some external ordanance that you wish to not use and keep the look of the plane "sleek"?
Thanks Jeff.
Correct, the holes in step 5 are for sidewinder rails or pylons. I am not using those or the additional tanks. I am only going to add sidewinders and rails to the wing tips. That is the look I want. ;)
Started the landing gear assembly.
The halves of the fuselage are then joined…
Then I finished painting the fuselage and did some weathering…
Next I will add the wheels…
Then I will add the tail wings and the main wing. Decals can start after that!
See ya next time…
