My 1/72 scale aircraft
F-104 Starfighter update…
Started the landing gear assembly.
The halves of the fuselage are then joined…
Then I finished painting the fuselage and did some weathering…
View attachment 580815View attachment 580816View attachment 580817
Next I will add the wheels…
Then I will add the tail wings and the main wing. Decals can start after that!
See ya next time…
Looking great ! Silver is another color that can be difficult to paint. :)
The F104 has an interesting shape, like a human guided missile. There's not much wing area for lift so it must be mostly thrust that keeps it airborne.
Yes, sometimes referred to as the “manned missile”, it has a high stall speed and thus a fast landing speed and typically used a drag chute when landing.
It set a lot of records for speed and altitude when it came out.
The F-104 was one of many nicknamed "The Widow Maker" for high crash and accident rate, due to lack of glide ratio when engine failed, or stalls due to poor aimanship.
Thanks Jeff! Yes silver can be streaky, like white and yellow, if not kept mixed and diluted properly. I brush on very thinned and use several coats. And of course I keep my hair dryer close by to dry between coats. That helps. ;)
I painted the canopy and went to install and the seat was too high…grrrr! Not sure how that happened…so I broke it out carefully and sanded the bottom until the canopy would clear it. Then glued it back in and did some touch up paint. When removing the seat the HUD was knocked off never to be found again! So I made another one with spare parts. I keep a box of spare parts from everything I have built. As you can image, after 80 plus models, I have a lot of spare parts and decals!
Anyway, the canopy finally went on.
Then I clear coated the entire airplane and somehow knocked off the pitot tube, which is why I usually wait until very last to put them on. So that was glued on again.
Then the sidewinder missiles were painted and decals added. Then they were glued on and the rear wing was knocked off…wow…someone needs a break! ROTF So I repaired that and did touch up paint.
So although it doesn’t look like much progress, it’s been a lot of work! I also started painting all the landing gear doors.
I hope to wrap this one up in another day or two.
See ya next time…
F-104 Starfighter done! Finished! Completed!
I had my reservations starting this one about how I wanted to paint it. But I’m happy with the outcome.
First the landing gear and doors were completed…
It was tedious, but I’m used to it. Doesn’t mean I like doing it. ROTF
Final pics…
On the work table…
Well that’s it, see ya next time!
Well, it’s hard to believe I already have 82 airplanes on my shelves.
This week I purchased…
WW1:
Sopwith 1-1/2 Strutter (dual seat w/ rear gunner)
Be2c RAF
Jets:
F4D Skyray
X-29
Other:
RWD-8 DWL polish trainer
So…I continue to purchase and build. However purchasing has slowed down a bit.
I need to spend some time on my ship. So I may wait a week before starting another aircraft. Will see! ;)
Thanks to everyone for your input and feedback. I’m glad there are airplane enthusiasts who join my builds…and some onlookers, who despite not sharing my aviation passion, still stop in to check on me.
