Drill bits.
Hi, I used high-speed Steel Reamers: Accuracy: H7; Cutting Diameter: 1/8" to convert my both DSPIAE to 1/8. It was easy to turn by hand. Works great, excellent precision and much easier to find 1/8 bits vs 3mm. Not promoting, but DSPIAE is very light and has good precision.
Best,
Yuri
that's a done deal! good job saving yourself a headache. dentist burrs are fabulous n come in so many types n , materials. my dentist gets them for me at wholesale prices. he loves my many hobbies, we share many common interests. i dont mind going to the dentist.
Hello everyone. I am trying to find a source for a micro twist drill bit set for my DSPIAE electric sanding pen. Because of the way the collet is designed it will only accept a 3mm round shank. I have looked online and nothing I have found lists the diameter of the shaft. And just to be clear it won't accept 3/32" or 0.11811. I have found some adapters with a 3mm shaft that accept different bit sizes, but I don't recognize any of these companies.
Have you looked on Temu? They have a vast amount of micro drills on their site at very low prices. I recently purchased a 50x1mm set for just £3.65 as I use these regularly and there's plenty of other sizes to choose from inc a mixed set.
Hi Bluenose2
In the attachment there are dril bits from Dremel (suitable for wood-shaft diameter 3 mm) & Proxxon drilbits (shaft 2.32 mm- for metal and wood. The 2.32 mm shafts can be wrapped with tesa band or something similar for fitting to the chuck . Another solution can be to substitute the original chuck with a varıable one if the original one is removable ofcourse.
Kind Regards
I found it interesting that DSPIAE includes a burr with the pen that is a 3mm shaft. However the carbide drill bit set they sell doesn't. They have a 1/8 shaft. I suspect it is for their hand drill. My new set is on its way from Japan as we speak. Couldn't return the DSPIAE set as I tried to drill a hole with my Dremel in the drill press and one of the drill bits broke. Much good info from everyone as to what these types of bits are used for.
carbides are very fussy with feed n speeds and any undue inaccuracy in the quill is unforgiven as you noticed. let them do the work n dont push m too hard. it takes some practice to develope just the right hand.
you'll enjoy the 1/8" shaft bits. inexpensive and the variety is amazing. i have a nice 1/8" shafted chuck that allows me to use regular bits and grinder stones.
My personal experience
A drop of machine oil specially while drilling with bits 0.8 - 0.5 mm and using high speed and not immediate but successive drilling pressure and patience and a balanced fixing to the chuck reduce the risk of breaking of the bits.
