Thank you !!! But I think this built isn't at that level. You have to take a look to the ones I posted at the start. Nevertheless, it's very appreciated!!!WOW!! Trophy good!!
HAHAHA, or to crush the guys feets is they drop out of the stacked position.Love the double stacked cannon balls!! Ready for a long battle...
Thank you Brad !!! I think, at this stage of the built, at least I can glue a small cleat and attach the rope to it. Will not be the full system as in the drawing, but will be better than leaving them hanging. I will have to place a cleat at each side of my deck beam. I was lucky that the 2 holes entries just happened to be at each side of that beamDaniel,
Thanks for finding my build worthy of getting ideas from! I'm flattered.
Your cannons are looking awesome!
The metalwork on the ports and hinges look superb!
Those ropes up by the ceiling (that hold open the cannon port lids) would have been attached to a small cleat up on that beam running above the cannon. See A in the below photo.
Thanks for sharing.
I agree 100 % . His skills for small scale modeling are truly exceptional. The bread owen he built was a Jaw dropping work. I wasn't able to at least try to do something similar.Following Brad's example is always wise.
Daniel,
Thanks for sharing.
I'd call that a WIN!Not correct, but better than letting those ropes hanging. This is the best I was able to do at this stage of the built. I didn't thought about those ropes when I had more space to work on that area.
View attachment 581991View attachment 581992
Now I have to built the other side cannon port.
Cheers
Daniel
Thank you Paul !!!I'd call that a WIN!
True storyWOW!! Trophy good!!
Another true storyFollowing Brad's example is always wise.
Good morning Daniel. No comment needed that pic says it all….stunning.Not correct, but better than letting those ropes hanging. This is the best I was able to do at this stage of the built. I didn't thought about those ropes when I had more space to work on that area.
Cheers
Daniel
Cheers Grant
Wow, you made awsome a great kit. Congrats!
