HMS Enterprise 1774 POF 1:48.
Grant , this is becoming one of those awesome builds. Your attention to detail is amazing. I know just how much skill and effort you’re putting in. Thanks for sharing, builds like this are inspiring
Good morning my shipbuild friends from around the world.
Time for a little detail. Treenails…. I don’t have a drawplate and after paying tax (He was mean to me this yearCautious) and two weddings my disposable income is limited. We also bought a warehouse in the company so no dividend for poor me this year end ROTF. So……Grants way of making treenails with no drawplate.
I used the same wood for treenails as the planks themselves as I wanted subtle and not a ship with measles ROTF.
I cut a 1x 1mm strip and then turned them down to approximately 0.5mm dowels using my lathe.
I made them a little pointy as there was no way of getting it exactly 0.5mm on a lathe.
Drilled a 0.5mm hole and with a tiny tiny tiny drop of CA glue inserted into deck and cut with nail clipper.
The outcome after gentle sanding with 220 grit. I oiled these for the photos as you don’t see them without. Note to self….dont oil where I need to glue!
View attachment 581298View attachment 581299View attachment 581301View attachment 581303
Ultra close up
Cheers Grant
Nicely scaled treenails, Grant.
The treenailing is looking great.
Thank you very much imdeed
Treenails are PERFECT! But each one through the lathe??? Since when did you become patient? ROTF
Hello Paul. Thanks. They are close to “Grants perfect;) “ and I am holding thumbs that when there are plenty dotted around it will still look OK. Nope patience still eludes meROTF. They go pretty quickly, so it seems, however this may change as I move along. I’m doing a row for each frame and while this model doesn’t have the correct framing there will still be plenty to do.
Good morning Ken. Thank you kindly. I feel like a bowler playing cricket where the batsmen got some runs on the board but no guarantee…..I have something to work with so I’m encouraged at the moment.
Beautiful !!
Thank you Jeff. I appreciate your comments and checking out my attempt so far.
Good morning Peter. Thank you kindly. Lets hold thumbs it will look good when done.
Firstly my congratulations to the family and, most importantly, to the bride and groom.
No doubt a laborious process making those treenails but the outcome is excellent. The photos show how effective they are.
Thank you Roger. They just got back from their honeymoon last night and look like newly weds living in La La landROTF. As they say now the honeymoon is over the real life starts….Im excited for them.
So far I’m in the honeymoon stage with my treenails ROTF let’s see how long my patience lasts.
I think they look great and very subtle but you still see them.
Thank you Neil. Often these little things look good as an example but turn into a bad bought of measles…..I am hopeful tho.
Cheers Grant
great, my dear friend
I'm sorry I missed all the joy, so first of all, congratulations on your birthday and congratulations on your son's wedding, may you know many more moments of happiness and joy in the family.
You're doing an amazing job on the model, well done, friend.
Whew - The guys are busy. I have spent an hour and a half going through logs this morning and still not done:D. Good on everyone.
Ricochet rabbit at his best.
Some more treenails
Got bored…
Cut some glass:
Broke more than I could actually use…so..
Blackened cannons and started making some
I only blackened the cannons once and buffed with a dremel. I quite like the “used” look so may not re-dip these.
Cheers Grant
Your work continues to be wonderful, but I REALLY like the way that internal bulkhead looks !!!
People won't see the pieces you broke, only the ones you installed. :D
Good afternoon Jeff. Thank you for the compliment I do appreciate this. True story re the glass however I need to find a way not to break so many as I will run out of this 0.02mm glass I have.
It is SO GREAT to see the appropriate cannon pattern, Armstrong Fredericks, for a ship of 1774. That is impressive and a nice change! Well done.
Thank you Allan. I just got lucky as these came with the kit- so kudos to Tom and CAF.
I agree with Jeff, that bulkhead panelling and glasswork looks terrific. The aged cannon blackening and buffing is very effective too.
Thank you kindly Roger. If I can get all the cannon looking similar then I will leave them as these came out, otherwise a second dip of blackening will be required. Cheers Grant
Good afternoon from a blustery Melkbosstrand.
Some more treenails. I also decided to nail the wales on each frame- wale messy again:
Broke my last 5mm drill bit. Ordered some better bits so hopefully these will last longer.
Scratch built my breast hooks around the hawes holes and shaped some lead to represent the iron sleeve:
Cheers Grant
Didn't know the ship was that big. 5 mm thick treenails...... WOW!
She is massive…. 1: 4.8 scale Stephan. ROTF.
Yep my 0.5mm drill bit it should be.
Another case of the measles! Where’s the ship doctor? ROTF Just kidding, she’s looking good Grant!
The measles are getting worse ……major outbreak still to comeROTF. We shall see if I have the cure once we sand and oil these….. maybe the ships doctor will be needed.
Cheers Grant
The lead linings make more sense than iron for your Enterprise. I don't think they used iron until much later, circa 1850-1860, driven by the adoption of iron anchor chain so lead would surely be more appropriate as you have done. For smaller scales grey paint as described in TFFM by David Antscherl makes a great substitute.
Thanks Allan. After reading Goodwin properly you are correct the wrought iron linings came much later when the iron anchor chains were introduced rather than hemp. There was also a time when oak linings were used with the hemp cables however Goodwin doesn’t put a time to these. Maybe I got lucky with my lead, I don’t know, but it was way easier than attempting the oak lining ROTF . You are correct tho the pic I included was definitely for ships built in the 1800’s. Cheers Grant
