This would for the HMB Endeavour. The colour is what I would have thought. Just wanted to see if anyone had a witches brew that they had come up with. Thnx.Hi BN2
What ship/year is this for?
I am joking but I wonder if you could actually make your own.tar, pitch, and brimstone. I highly doubt any two batches of the mixture ever matched in color exactly. And then once in the water, the color probably changed as well. Probably any dark brown would be appropriate.
Brain Lavery describes this coating in The Arming and Fitting of English Ships of War on page 58.
Brown stuff (the tar, pitch and brimstone formula) was common at the time of Endeavour so a smart choice. An interesting thing ------ About 1777 the navy only used it to about 3 feet below the load waterline to save money and used tallow and lime above the brown stuff. Never saw this on a model, but would surely raise some conversation.
Sounds about right. I'm going to mix up some oil based product and spray it with my airbrush. That way I can go back and add or rub out some colours on some of the planking as I see fit. The hull colour would probably be a little variegated due to the grain and amount of product each person applied. I'm going for a look that would be appropriate for a ship that has been at sea for a while. We'll see.Start with burnt umber (aka Van dyke Brown). Play with different colors; white, light brown, grey until you’re happy with it.
Roger
These are some thoughts to consider before you step off the cliff:The hull colour would probably be a little variegated due to the grain and amount of product each person applied.
I get where you're coming from. Something to note is that the bottom of the Endeavour was payed with "brown stuff" not anything white. Being that part of my modelling background is in armour, shading and weathering is essential to a finished product. As a finishing carpenter I would not use an alcohol or water based stain in this case for very good reasons. There is no room for error on raw wood. Water and alcohol evaporate immediately leaving little room for adjustment. For this reason I spray these products with a gun when I am finishing cabinets etc. Using oil gives me the advantage of going back with thinner and subtly altering the finish in spots "I" choose to give a more variegated finish. Realistically in my opinion the hull would't be a solid brown or black but a combination of both in moderation to capture the essence of the art if you will.These are some thoughts to consider before you step off the cliff:
I could easily be where you are. My preference is stylized framing. What framing that I have is more than enough to support planking. My style is not Navy Board, but can be taken for it. My purpose is to attempt an artistic style that is true to original in spirit. At our scales, I think that and actually see that it is easy to produce something that is too literal. Art and illusion is much more difficult and requires a degree of finesse. I requires practice and taste. It is more difficult. I see that a successful result as being more pleasing to view. In my case my reach far exceeds my grasp. Ambitious goals are worth having.?
If I planked the bottom I would want to show that off. That you have to ask the question about the color is a reflection of a situation where there is not enough information to simulate actual historical accuracy. If I had to and intended to make a guess anyway, I would go for art and suggestion. I would go with a subdued white. I would see if I could find an alcohol based aniline dye that is white. The planking pattern and grain would survive that. If not such dye is possible, I try a thin semi-transparent enamel wash of off white.
I keep seeing kit paint jobs where the thickness and complete opacity of the paint overpowers the wood under it and steals the show. Perhaps part of it is that water based acrylics are used. Perhaps it is that the very nature of the acrylic polymer cannot avoid looking thick and chalky. Whatever the cause, the result just does not look realistic. My hope is that there has to be a better way. Less is better. A hint is better. I having the thought that if I made a visible layer that was able to simulate "a little variegated" and demonstrated a difference in the "amount of product each person applied". I would not like the overpowering look that would have to be a part of the result.
