- Jun 2, 2025
Bunnings here in Australiai like the counter top material. where did you get it?
I want to make apx 2mm rope. I need about 3 or 4 meters. Will run some tests over the next few days.Congratz, it looks good.
The machine is designed to setup both switches in the same direction. If you make RH rope both switches in stand I and cable/LH, both in stand II.
The Gutterman Tera 20. 3x2, Went to 15%. Any less and it was not wound up enough. I had 28 gram weight but there was some friction between the Bok and the bench shelving, which is why I only used 28 grams of weight.What yarn did you use for the test?
Maybe instead of going to 15% and 28 gram of weight. Would increasing the weight and reducing to 10% wound it tighter?If you follow the 10% rule, this is 10% of the distance between the hooks of the “BOK” and the “WIEL”. You can also add a little more weight to get a tighter stroke in your rope, or experiment with the adjustment screw on the “KLOS”. Applying just a little resistance to the cable makes a world of difference. Have fun experimenting.
My mistake. I had 200grams weight not 100.View attachment 586872
I think section A was attached to the “BOK” and section B to the “WIEL.” The difference in stroke is noticeable. When you reach 10%, both machines should continue running at roughly the same potentiometer setting. And I think you can add more weight.
Otherwise, you're well on your way to making the perfect rope. This is already very nice, especially the section on the A side.
Yes. I think I did run a different speed on the bok than I did on the Weil. So I need to make sure I run both at the same speed?View attachment 586872
