fishing sloop build
goodmorning all,
let me first introduce myself. My name is Rob and I am living in the Netherlands. About 30 km above Amsterdam in the Northwest part. My english is rusty but I will do my upmost best to make a story what is worth it.
I am already for a longer time following this site and it's helps me a lot answering questions how to make a model. So, it is about time to start a thread from my own build. I am interested in old fishing boats from the Dutch history. Because the waters in Holland are often very shallow they build in the early days fishing boats that are not provide with a keelson and with a flat bottom. These ships were able to run dry when the water was low during the tide.
In Holland (aka the Netherlands) we have also a modelbuilding site and on this site I already have finished a thread from another build of an old fishing boat:
At this moment I am building from plans an a few books a fishing sloop. This ship was capable for a longer stay on sea and they went further from the coast, much further. This model is based on a replica of an old ship. This replica is build by a group of volunteers under the leadership of an experienced ship carpenter. The volunteers were unemployed and the idea was to help them to a new job in this direction. About this build there is a book available with a step by step explanation how the build was realised.
Without few advice from the author, this book and the threads about ship modelling which are available on the www it was for impossible to start building myself. So also thanks to you all.
It is the first time for me to build a model plank on frame, so it will be an exciting try out. At this moment the build is already in an advanced stadium. the scale of my build is 1:20. All my models are in this scale. This sloop is in length approximately 18 meter, so it will be a large model.
Thanks.
Thanks Allan!
the first thing to build was the stern, the bow. These parts where reinforced on the keel with steel by the real ship. As I build the ship in oak ( the original ships were also in oak) and I want to leave it in oak color I made these reinforcements in brass which is chemical coloured. Carried out in steel make stains on oak.
The bow and stern attached on the keel together with the reinforcements. In combination with the deadwood.
In the later days these sloops had an engine. The replica certainly have an engine so I take a facilitie for a propeller
Thanks for posting the photos!. Sometimes it easier to use copper than brass. It is softer, easier to work, especially when making rings and can be blackened in situ with diluted liver of sulfur. A $10 small jar of LoS will last you about 100 years in our hobby. :)
Happy to share it Allan and glad you like them and thanks for the likes and interest
The keel from this ship was to long for making it out a single beam oak. So it was devided in two pieces. They were connect to each other in a way that was both strong enough and watertight. The keel was also provided with a saving for the first plank of the skin. Due the changing corner from this plank towards the keel this saving also provided a changing corner. The keel is also provided with free spaces to insert the rafters
Hope everything is clear despite my english I use Google translate sometimes
Best regards, Rob
goodmorning all,
Thanks.
Welcome to SOS. Interesting story. I'm all in. Neat precise milling, how many models have you built in total. Is this work by hand or milling machine.
Thanks Ted,
This is my fifth model.
The spaces in the keel are made with a milling machine. The rest is by bandsaw and by hand. The space in the keel for the first plank is done with several blades wich I shaped in the right silhouet.
Thanks Ted,
Really neat work. I never made and shaper blades but have had them made for trim work on custom high end remodels. You're going to enjoy this group.
goodmorning all,
Thanks.
Mooi werk. Van harte welkom, Rob!
Thanks Cees for your nice words and welcom.
Thanks Ted for your positive feedback. This is indeed an enjoyable group. As the quality of the models you are all building I think it will be a challenge for me to keep up with you all.
I also started this thread to challenge myself. There is no way back now ;)
In the mean time I am allready further with the model. I will post every now and then an update.
The rafters of this ship were Made of two layers of oak. The pieces of the layers where covering each other to become a sturdy frame.
One layer will be finishing below the deck and the other layer will be the railing.
I am glueing the two layers and nail them together. As one layer will go through for the railing the other layerpart above the deck must be removed. In order to make this possible I put plastic foil beneath the two parts, so that it is easy to separate them.
The paper wich I became due lofting the frames with the bevel of the rafter glued on top of it with rubbercement so that the paper is easy removeable.
Removing the part that will be above the deck:
And nailing and sanding. The nails on the real ship are steel. To avoid stains from steel on oak I use brass. To keep it on the right scale the brass is 0,8 mm.
All of this I learned from internet shipmodellers. So thanks to you all!
Have a nice day.
goodmorning all,
Thanks.
Nice to see you here on the SoS, Rob. And nice to see the build of another Dutch fishing vessel. Perhaps a chair besides Paul …… ?
Very nice work, Rob. I'll pull up a chair...
Thanks! You are very welcome
Hi Peter, thanks for your welcom and advice.
My wish is to build this vessel according your models. So leave it open for a part to see the whole construction. Hopefull with the same quality of your models. Fingers crossed I shall do my upmost best.
the waterlines in the drawing are close to each other and so it is difficult to loft the frames. I made new drawings with the waterlines in colours. This to minimalize the risk on faults.
Best regards, Rob
Best regards, Rob
Hi, I was wondering: did you choose the joints on the keel yourself? Frank
Thanks for the likes! Very pleased with it and support me to go further
The fixture is well done indeed. This is going to be a fun build.to follow
Thanks Ted! You are very welcome.
I found a book with the whole history of the build of this replica. This book is filled with very much pictures and drawings. The joints in the keel are also used by the build of this replica.
As old fisherboats are having my interest I was also very glad to find a book written by a shipbuilder how these ships were made. Translated in english; from tree to ship. The build of an wooden fisherboat.
There are a lot of Brooks available from ancient fisherboats. This book however is rare and difficult to find. Takes me lot of time to find it. Luckily I bumped into it in an old bookstore.
Thanks for your interest !
Sorry, I didn't mean the joints—I meant the notches on the keel. Frank
