- Jun 29, 2024
I thought that I’d never be shopping for a Dremel tool BUT:
I’ve reached the point on my present model where I cannot use my favorite drilling method; drill press. I have a Dremel Mighty Mite that’s about to give up the ghost and with apologies to my friend Bob Cleek I don’t want to spend the $$ for a Foredom tool.
My needs:
Slim design to get into tight spots on the model.
Chuck or collet that closes to zero to use wire sized HSS bits, NOT those proprietary bits with larger shanks
120v motor, NOT cordless.
I don’t need it for sanding, cutting, grinding, etc. Just drilling.
The tool that seems to best fit my needs is a Dremel Stylos. Although classed as”Light duty” my on the model drilling is limited to holes under1/16.” Everything else goes to the drill press.
Roger
My needs:
Roger
