The dead eyes, I can make, but the single blocks are tiny, on a block only 73 thou wide, not achievable with the sheave, nor the double sheave block either, so I will make a mock-up and try to make them as real as I can.I would guess most folks that want working sheaves make their own blocks in pieces same as an actual block with tail piece, crown, etc. They look great on the largest blocks but maybe not worth the effort on smaller blocks as the line running through the block obscures most of the view of the sheave in most cases.
Do you have a small mill, Gary? If so, here is how Ondras makes blocks:The dead eyes, I can make, but the single blocks are tiny, on a block only 73 thou wide, not achievable with the sheave, nor the double sheave block either, so I will make a mock-up and try to make them as real as I can.
Wow, that blew me away. I have a small and very old lathe that I use like a Milling machine. I will give it a go once I get a chance to do so. BTW, what a modeller he is!Do you have a small mill, Gary? If so, here is how Ondras makes blocks:
Roter Löwe 1597 by Ondras71 - scala 1/60
Witaj Ondras wygląda jak prawdziwy, świetne wykonanie .Pozdrawiam Mirekshipsofscale.com
Thank you very much Paul and Mirek.Coffee-Cup All five Stays Mouse done.. Shrouds and Stay Mouse are strung..Explosionshipsofscale.com
There are several others but it would take some hunting down.
I am not aware of anyone putting working sheaves in miniature blocks.
This is pretty much what I have done for block making but added one more step. Sand them in a block sander with a drill. Hand held drill works great. See Tricks of the Trade https://shipsofscale.com/sosforums/threads/tricks-of-the-trade.15492/ post #3 Check every 20 or 30 seconds to be sure it is not too much. Good wood like box or castello will take a will longer than bass or other soft woods.Using a razor hand saw, cut each block from the stick. A needle file should be used to extend the shallow groove to hold the strop across the top and bottom of the block.
