Making Blocks and sheaves for a 1:48 scale model.
  • Thread starter Thread starter GaryA
  • Watchers Watchers 7
Hi everybody,
I am wondering what modellers do to craft the different types of Blocks and Sheaves for their models, built at 1:48 scale?
I would guess most folks that want working sheaves make their own blocks in pieces same as an actual block with tail piece, crown, etc. They look great on the largest blocks but maybe not worth the effort on smaller blocks as the line running through the block obscures most of the view of the sheave in most cases.
The dead eyes, I can make, but the single blocks are tiny, on a block only 73 thou wide, not achievable with the sheave, nor the double sheave block either, so I will make a mock-up and try to make them as real as I can.
Do you have a small mill, Gary? If so, here is how Ondras makes blocks:
There are several others but it would take some hunting down.
I am not aware of anyone putting working sheaves in miniature blocks.
Wow, that blew me away. I have a small and very old lathe that I use like a Milling machine. I will give it a go once I get a chance to do so. BTW, what a modeller he is!
You know, I put in a search on SOS, but I did not dig up Ondras's page. Got it now though. ;)
Some people don't make them, but buy them. There are many merchants out there and there are a number that are on these forums.
of course, there are MANY different sizes on a single ship, so there is not one that is 1/48 scale. Most merchants will sell several different sizes and types. :)
There are many different ways to make blocks depending on scale and available tooling. For the relatively large blocks required for 1:48 scale, the “stick” method works fine if you have a Byrnes or, other miniature table saw and a way to accurately drill small holes.
Using the table saw:
1. Rip a stick of hard close grained wood to the cross sectional dimensions of the block.
2. Cut one or more deep grooves in the both the top and bottom of the stick.
3. Cut one shallow grooves in in each side of the stick.
Using the drill:
1. Drill a pair of holes spaced the diameter the sheave through the deep grooves of the stick. The result will be a row of pairs of holes along the stick.
2. With a tiny burr, soften the inside edges of the each hole to replicate the circular shape of the sheave.
With your favorite hand tools, carve but do nor separate from the stick each end of each block. Files or better yet emery boards can be used to smooth sharp corners.
Using a razor hand saw, cut each block from the stick. A needle file should be used to extend the shallow groove to hold the strop across the top and bottom of the block. I have a collection of simple homemade wooden miter boxes that I use for cutting multiple small pieces to exact lengths. I don’t like the aluminum miter boxes that come with razor saw kits.
Roger
This is pretty much what I have done for block making but added one more step. Sand them in a block sander with a drill. Hand held drill works great. See Tricks of the Trade https://shipsofscale.com/sosforums/threads/tricks-of-the-trade.15492/ post #3 Check every 20 or 30 seconds to be sure it is not too much. Good wood like box or castello will take a will longer than bass or other soft woods.
Hi everybody,
There were several long articles published in the NRJ about a dozen years ago that covered this precise subject in exhausting detail. I think they would cover any questions you could invent. I have constructed thousands of blocks over the years using these techniques. You can make any block, any size, any style - no problem. Boxwood would be the preferred wood.
Using the drill:
1. Drill a pair of holes spaced the diameter of the sheave through the deep grooves of the stick. The result will be a row of pairs of holes along the stick.
Roger
No pics, Roger, as to how detailed you can get these pulleys to be? I can also look at a pulley but it means nothing to me unless I can scale it to something
Hi Bill, what is the NRJ?
Sorry Gary, what I posted is the best that I can do. The model that I am currently building will eventually require blocks (for the cargo gear) but that’s way down the road and at the scale that I’m working to (1:96) they’ll probably be machined from brass using a technique that the late master modeler Gerald Wingrove wrote about.
The NRJ is the Nautical Research Journal once the pre-eminent quarterly maritime research and ship modeling Journal. Back issues are a treasure trove of information. Sadly the Journal “ain’t what it used to be.”
Roger
Roger
Thanks Mate. Actually, come across a bloke making them on YouTube. He was using a Proxxon Milling machine and looked ok, but a lot of hand work to create one. I actually bought a router jig for my Dremel, and I could probably give that a go, when the time comes. Dremel has a few carbide cutters that I also bought.
In my book I have, Anatomy of a ship, The Armed Transport Bounty does have details of the pullies used and very good detail, but I may have to ask people here about a couple pulleys that I am scratching my head over. Also, in the details of what type of pulley to be used, seems to be a little sketchy to me also.
Do you have the book?
This is what AI search says….
AI Overview
The Nautical Research Journal (NRJ), published by the Nautical Research Guild (NRG), is a renowned quarterly publication for maritime researchers and ship modelers. It features in-depth articles on ship designs, naval history, and modeling techniques, serving as a key resource for enthusiasts interested in maritime history and high-quality research. [1, 2, 3, 4]
