true storyIf I had to describe it in one word, it would be "magnificent".
Thank you so much Paul!As always it is a joy to see your work, Mustafa. Everything looks excellent!
hello,After working on the main and fore yards for a while, I returned to ratlines and completed the main and fore upper ratlines as well.
I had added sails to the first two models I built, but I couldn't achieve a realistic look. Therefore, I no longer add sails. I won't add sails to this one either.hello,
I was just wondering if you were planning on putting sails on your boat?
I purchased the sail kit from Model Expo. I am going to try and install the sails, unfurled.
Thanks for your comment, Jerry. I definitely agree, Constitution has jackstays, but I was too lazy and decided not to add them to my model.Constitution most certainly had jack-stays at the point you're depicting her, and no one will knock using wire for the stirrups of your foot-ropes; maybe something a little less Jules Verne?
I use PVA (wood glue) diluted with water, which dries clear.What glue do you use on your ropes Mustafa? They look incredibly clean.
