wow ! That is amazing ! No wonder they don't make ships like that any more !
Your work is beautiful !
You give us a nice ‘inside view’ of the complexity of this build, Daniel. A lot of parts have to be aligned. And about your joinery skills …….. the dovetail’s looks very nice. No problem at all.Here is a little more progress with the gun-deck support system. With each repetition it seems to progress a little quicker. First, I set the canon port standards then the gun deck support beams which have the dove tail slot at the bulwarks. These beams will get trimmed along a line that creates the deck stepdown, but I first have to install all of them in order to know exactly where to trim by setting the prefabbed decking with grates on them then marking the cut line. The template they provided DOES NOT match the decking profile, again no surprise there. Check it out.
View attachment 588462View attachment 588463
Where the gun deck support beams marked 1s,2s, etc. cross the bulwark standards I have to trim out a notch where they lay flat onto the main deck. For now those members are just dry fit until I determine where to cut them off. Next a close in shot where I expose my limited abilities at joinery.
Hope you all find this informative and thanks for stopping in to take a look.
Good morning Daniel. As always fabulous modelling. OH Boy......that is a hectic challenge making all those notches each at differing angles and sizes. Love your deck. It is really cool to see all the complicates standards and deck beams (dove tail joints and all), makes for a brilliant Xebec. Cheers GrantHere is a little more progress with the gun-deck support system. With each repetition it seems to progress a little quicker. First, I set the canon port standards then the gun deck support beams which have the dove tail slot at the bulwarks. These beams will get trimmed along a line that creates the deck stepdown, but I first have to install all of them in order to know exactly where to trim by setting the prefabbed decking with grates on them then marking the cut line. The template they provided DOES NOT match the decking profile, again no surprise there. Check it out.
Thank you Jeff. It would seem the designers went out of their way to make the gun deck complicated.wow ! That is amazing ! No wonder they don't make ships like that any more !
Thank you Peter, I always appreciate your and all the others' opinions, very uplifting.You give us a nice ‘inside view’ of the complexity of this build, Daniel. A lot of parts have to be aligned. And about your joinery skills …….. the dovetail’s looks very nice. No problem at all.
Thanks Grant, a hectic challenge is the perfect description for this ship at this point.Good morning Daniel. As always fabulous modelling. OH Boy......that is a hectic challenge making all those notches each at differing angles and sizes. Love your deck. It is really cool to see all the complicates standards and deck beams (dove tail joints and all), makes for a brilliant Xebec. Cheers Grant
Thank you for your kind words Shota.Dear Daniel
I agree with all the compliments given to your amazing work and I would like to add my respects to you for your perseverance, patience and quality.
Thank you John!Daniel,
Nice update indeed - looking so good
Thank you for those encouraging thoughts, Bluebeard! You just put into words a lesson I will keep in my toolbox.Honestly, sometimes the model tells you how it wants to be built
Thanks Paul, the structural aspects of this ship are indeed different.Pretty crazy construction...
You've got this, Daniel!
A complex construction where a lot of dry fitting is needed, as you wrote, Daniel. A real challenge.Time fly's when you're busy. It's been 6 weeks already from my last post so here is a little more progress. My focus is the starboard gun deck support structure and perhaps the most difficult area I have ever faced on any build to date. There is an "L" shaped strip of wood that serves as the step-down edge with the decking laid into it and across the support beams that span across to the bulwark assemblies. I have glued and removed that piece 3 times now. The first couple
of shots I'm just trying to dry fit to see how the decking is really going to fit.
I would like to install the decking as shown, not separated into each plank but it is looking like that will not be possible and I'll have to glue down each piece separately.
View attachment 601845View attachment 601846View attachment 601848
For now, it may look like that precut fabricated deck sheet should just lay right in on the supports, but it just doesn't want to so it's going to be one plank at a time.
Thanks for checking in and by the way who ever made the decision to add "Similar threads" following our post, thank you, I Love it! AI assist?
Thanks Peter, I appreciate your observations.A complex construction where a lot of dry fitting is needed, as you wrote, Daniel. A real challenge.
wonderful work my dear friend Daniel!!Time fly's when you're busy. It's been 6 weeks already from my last post so here is a little more progress. My focus is the starboard gun deck support structure and perhaps the most difficult area I have ever faced on any build to date. There is an "L" shaped strip of wood that serves as the step-down edge with the decking laid into it and across the support beams that span across to the bulwark assemblies. I have glued and removed that piece 3 times now. The first couple
Thank you so much Shota.wonderful work my dear friend Daniel!!
The deck looks fantastic
